Error while exporting without GUI
4 years 10 months ago #3401 by Amilibia i Sison
I'm just getting started on Netgen on Mac. I wanted to upload a surface mesh, generate a volumetric mesh with certain parameters and export it later. I was able to import the mesh and generate the volumetric mesh. But after generating the mesh, the GUI opens and the following error appears:
AttributeError: 'builtin_function_or_method' object has no attribute ‘Export'
I was wondering if you guys could help me export the mesh. Here's my code attached:
FREECADPATH = '/Applications/Netgen'
import sys
sys.path.append(FREECADPATH)
import netgen.meshing as meshing
from netgen.NgOCC import *
geo = OCCGeometry('/Users/emilio/Desktop/tfgs/skull_solid_step.step')
mesh = geo.GenerateMesh
mesh.Export("test.msh", "Gmsh Format")
Thank you!
4 years 10 months ago #3402 by cwinters
you have to call the GenerateMesh function
mesh = geo.GenerateMesh()
then the export works.
You just copied the GenerateMesh function to the new function "mesh".
