Boundaries of open surfaces
4 years 11 months ago #3339 by Bittermandeln
I want to do a boundary integral for an open surface, namely a half-cylinder, in order to implement boundary conditions in the Nitsche fashion. Parts of my code now look like
r = 1/pi
cyl = Cylinder(Pnt(0,0,0), Pnt(1,0,0),r)
top = Plane(Pnt(0,0,0),Vec(0,0,-1))
left = Plane(Pnt(0,0,0),Vec(-1,0,0))
right =Plane(Pnt(1,0,0),Vec(1,0,0))
shell = (cyl * left*right*top)
geo.AddSurface(cyl, shell)
bnd_D = mesh.Boundaries("dir")
in order to define the mesh and the boundary. I then perform the integral using e.g.
a += SymbolicBFI(InnerProduct(p*mu, v.Trace()), BND, element_boundary = True, definedon = bnd_D)
However, it seems that NGSolve skips this integral. Does anyone know what I am doing wrong?
Alvar
4 years 11 months ago #3340 by mneunteufel
Hi Alvar,
you only access boundaries labeled with "dir". But in your presented code no such label appears.
With e.g.
cyl = Cylinder(Pnt(0,0,0), Pnt(1,0,0),r).bc("dir")
you can label the surface.
4 years 11 months ago #3345 by Bittermandeln
Hi Michael,
Thank you for your answer. I have now rewritten the code to be
r = 1/pi
top = Plane(Pnt(0,0,0),Vec(0,0,-1)).bc("dir")
left = Plane(Pnt(0,0,0),Vec(-1,0,0)).bc("dir")
right =Plane(Pnt(1,0,0),Vec(1,0,0)).bc("dir")
ngmesh = geo.GenerateMesh(maxh=0.3)
ngmesh.SetCD2Name(1,"wall")
ngmesh.SetCD2Name(2,"wall")
ngmesh.SetCD2Name(3,"outflow")
ngmesh.SetCD2Name(4,"inflow")
bnd_D = mesh.Boundaries("inflow|outflow|wall")
with one of the boundary integrals looking like
a += SymbolicBFI(-2*InnerProduct(epsu*mu, v.Trace()), BND, element_boundary = True, definedon = bnd_D)
It still seems like the integral has no effect. Am I missing it completely? How do you do integrals on boundaries of a surfaces, i.e. with Co-dimension 2?
It is worth pointing out that v is in a SurfaceHDiv space and epsu is the symmetric gradient of such a vector. I also need to integrate vectors in SurfaceL2
4 years 11 months ago #3346 by mneunteufel
Hi Alvar,
I somehow got confused with the boundaries and co-dimensional 2 boundaries. In NGSolve co-dimensional 2 boundaries are called BBoundaries and the surface is still a boundary.
In this tutorial you can find how to define BBoundaries without guessing the right index for SetCD2Name.
So to access only the BBoundaries the correct syntax is
bnd_D = mesh.BBoundaries("inflow|outflow|wall")
But, I'm afraid that your code
won't work. I guess it will throw an exception concerning the traces. Integrating over edges in three dimensions with a SurfaceHDiv space is not well defined as there is no unique normal vector.
In this example to perform integration over a BBoundary for hyb in SurfaceHDiv the following trick has been used
bfA += Variation( -IfPos(x-L+1e-6, 1, 0)*(hyb*nel)*ds(element_boundary=True) )
to loop over all edges with the surface information at hand for the (element)normal vector and being 1 only at the BBoundary.
I hope this helps.
The following user(s) said Thank You: Bittermandeln
4 years 11 months ago #3360 by Bittermandeln
Thank you for your help.
Time to create page: 0.164 seconds
