H(div)-HDG on surfaces
5 years 5 hours ago #3318 by Bittermandeln
I am trying to implement H(div)-HDG on surfaces for Stokes equation, following Lehrenfeld-Schöberl-Lederer, 2020. My code is down below. For some reason it never finishes inverting the bilinear form a, or at least not for the approx 10 mins I have let it load. I have implemented it for Vector Laplace and it works fine and quickly, so I don't really get what is the problem. I have tried to remove the stuff from the example code which deals with condensation to try to remove possible error factors. Anyone have an idea of why it doesn't work, or has anyone had a similar problem?
Best regards
Alvar
# basic xfem functionality
from numpy import pi
r = 1
sphere = Sphere(Pnt(0,0,0),r).bc("dir")
geo.Add(sphere)
order_u = 2
order_p = 1
mesh.Curve(2)
refinements = 1
for i in range(refinements):
print("Done with part 1")
print("Done with part 2")
n = specialcf.normal(3)
tau = specialcf.tangential(3)
mu = Cross(n,tau)
print("Done with part 3")
Wh = HDivSurface(mesh, order = order_u)
Wh = Compress(Wh)
What = HCurl(mesh, order = order_u, orderface = 0)
What = Compress(What)
Qh = SurfaceL2(mesh, order=order_p)
Nh = NumberSpace(mesh)
Vh = FESpace([Wh, What, Qh, Nh])
print("Done with part 4")
nmat = CoefficientFunction(n, dims = (3,1))
proj = Id(3) - nmat*nmat.trans
gamma = 4*order_u*(order_u+1)
force = CoefficientFunction(((-56 * z ** 2 + 36 * z) * x ** 8 / 2 + 18 * x ** 7 * y ** 2 + (-2 - 168 * z ** 4 + 108 * z ** 3 + (-168 * y ** 2 + 228) * z ** 2 + (108 * y ** 2 - 140) * z) * x ** 6 / 2 + (108 * y ** 4 + 108 * y ** 2 * z ** 2 - 140 * y ** 2 + 2) * x ** 5 / 2 + (-168 * z ** 6 + 108 * z ** 5 + (-336 * y ** 2 + 456) * z ** 4 + (216 * y ** 2 - 280) * z ** 3 + (-168 * y ** 4 + 456 * y ** 2 - 342) * z ** 2 + (108 * y ** 4 - 280 * y ** 2 + 198) * z - 4 * y ** 2 + 6) * x ** 4 / 2 + (108 * y ** 2 * z ** 4 + (216 * y ** 4 - 280 * y ** 2 + 4) * z ** 2 + 108 * y ** 6 - 280 * y ** 4 + 198 * y ** 2 - 6) * x ** 3 / 2 + (-56 * z ** 8 + 36 * z ** 7 + (-168 * y ** 2 + 228) * z ** 6 + (108 * y ** 2 - 140) * z ** 5 + (-168 * y ** 4 + 456 * y ** 2 - 345) * z ** 4 + (108 * y ** 4 - 280 * y ** 2 + 202) * z ** 3 + (-56 * y ** 6 + 228 * y ** 4 - 347 * y ** 2 + 208) * z ** 2 + (36 * y ** 6 - 140 * y ** 4 + 202 * y ** 2 - 113) * z - 2 * y ** 4 + 6 * y ** 2 - 6) * x ** 2 / 2 + (36 * y ** 2 * z ** 6 + (108 * y ** 4 - 140 * y ** 2 + 2) * z ** 4 + (108 * y ** 6 - 280 * y ** 4 + 198 * y ** 2 - 6) * z ** 2 + 36 * y ** 8 - 140 * y ** 6 + 196 * y ** 4 - 108 * y ** 2 + 4) * x / 2 + 1 - 0.5e1 / 0.2e1 * z ** 6 + 2 * z ** 5 + (-10 * y ** 2 + 17) * z ** 4 / 2 + (8 * y ** 2 - 11) * z ** 3 / 2 + (-5 * y ** 4 + 17 * y ** 2 - 24) * z ** 2 / 2 + (4 * y ** 4 - 11 * y ** 2 + 12) * z / 2,-28 * y * ((z ** 2 - 0.9e1 / 0.14e2 * z) * x ** 7 - 0.9e1 / 0.14e2 * x ** 6 * y ** 2 + (0.1e1 / 0.28e2 + 3 * z ** 4 - 0.27e2 / 0.14e2 * z ** 3 + (-0.57e2 / 0.14e2 + 3 * y ** 2) * z ** 2 + (0.5e1 / 0.2e1 - 0.27e2 / 0.14e2 * y ** 2) * z) * x ** 5 + (-0.27e2 / 0.14e2 * y ** 4 - 0.5e1 / 0.28e2 + 0.5e1 / 0.2e1 * y ** 2 - 0.27e2 / 0.14e2 * y ** 2 * z ** 2) * x ** 4 + (3 * z ** 6 - 0.27e2 / 0.14e2 * z ** 5 + (-0.57e2 / 0.7e1 + 6 * y ** 2) * z ** 4 + (5 - 0.27e2 / 0.7e1 * y ** 2) * z ** 3 + (0.337e3 / 0.56e2 - 0.57e2 / 0.7e1 * y ** 2 + 3 * y ** 4) * z ** 2 + (-0.97e2 / 0.28e2 + 5 * y ** 2 - 0.27e2 / 0.14e2 * y ** 4) * z + y ** 2 / 14 - 0.3e1 / 0.28e2) * x ** 3 + (-0.27e2 / 0.14e2 * y ** 2 * z ** 4 + (5 * y ** 2 - 0.5e1 / 0.14e2 - 0.27e2 / 0.7e1 * y ** 4) * z ** 2 - 0.27e2 / 0.14e2 * y ** 6 - 0.107e3 / 0.28e2 * y ** 2 + 0.1e1 / 0.2e1 + 5 * y ** 4) * x ** 2 + (z ** 8 - 0.9e1 / 0.14e2 * z ** 7 + (-0.57e2 / 0.14e2 + 3 * y ** 2) * z ** 6 + (0.5e1 / 0.2e1 - 0.27e2 / 0.14e2 * y ** 2) * z ** 5 + (0.335e3 / 0.56e2 - 0.57e2 / 0.7e1 * y ** 2 + 3 * y ** 4) * z ** 4 + (-0.97e2 / 0.28e2 + 5 * y ** 2 - 0.27e2 / 0.14e2 * y ** 4) * z ** 3 + (-0.191e3 / 0.56e2 - 0.57e2 / 0.14e2 * y ** 4 + 0.337e3 / 0.56e2 * y ** 2 + y ** 6) * z ** 2 + (0.51e2 / 0.28e2 + 0.5e1 / 0.2e1 * y ** 4 - 0.97e2 / 0.28e2 * y ** 2 - 0.9e1 / 0.14e2 * y ** 6) * z - 0.3e1 / 0.28e2 * y ** 2 + 0.3e1 / 0.28e2 + y ** 4 / 28) * x - 0.9e1 / 0.14e2 * y ** 2 * z ** 6 + (-0.27e2 / 0.14e2 * y ** 4 - 0.5e1 / 0.28e2 + 0.5e1 / 0.2e1 * y ** 2) * z ** 4 + (-0.27e2 / 0.14e2 * y ** 6 - 0.107e3 / 0.28e2 * y ** 2 + 0.1e1 / 0.2e1 + 5 * y ** 4) * z ** 2 - 0.15e2 / 0.28e2 - 0.9e1 / 0.14e2 * y ** 8 + 0.65e2 / 0.28e2 * y ** 2 + 0.5e1 / 0.2e1 * y ** 6 - 0.51e2 / 0.14e2 * y ** 4),-28 * z ** 9 * x + 18 * z ** 8 * x + (-168 * x ** 3 - 168 * x * y ** 2 + 36 * y ** 2 + 228 * x) * z ** 7 / 2 + (108 * x ** 3 + 108 * x * y ** 2 - 140 * x) * z ** 6 / 2 + (-168 * x ** 5 + (-336 * y ** 2 + 456) * x ** 3 + 108 * x ** 2 * y ** 2 + (-168 * y ** 4 + 456 * y ** 2 - 345) * x + 108 * y ** 4 - 140 * y ** 2 + 2) * z ** 5 / 2 + (108 * x ** 5 + (216 * y ** 2 - 280) * x ** 3 + (108 * y ** 4 - 280 * y ** 2 + 198) * x) * z ** 4 / 2 + (-56 * x ** 7 + (-168 * y ** 2 + 228) * x ** 5 + 108 * x ** 4 * y ** 2 + (-168 * y ** 4 + 456 * y ** 2 - 357) * x ** 3 + (216 * y ** 4 - 280 * y ** 2 + 4) * x ** 2 + (-56 * y ** 6 + 228 * y ** 4 - 357 * y ** 2 + 219) * x + 108 * y ** 6 - 280 * y ** 4 + 198 * y ** 2 - 6) * z ** 3 / 2 + 18 * x * (x ** 6 + (3 * y ** 2 - 0.35e2 / 0.9e1) * x ** 4 + (3 * y ** 4 - 0.70e2 / 0.9e1 * y ** 2 + 0.101e3 / 0.18e2) * x ** 2 + y ** 6 - 0.35e2 / 0.9e1 * y ** 4 + 0.101e3 / 0.18e2 * y ** 2 - 0.113e3 / 0.36e2) * z ** 2 + (36 * x ** 6 * y ** 2 - 12 * x ** 5 + (108 * y ** 4 - 140 * y ** 2 + 2) * x ** 4 + (-24 * y ** 2 + 34) * x ** 3 + (108 * y ** 6 - 280 * y ** 4 + 198 * y ** 2 - 6) * x ** 2 + (-12 * y ** 4 + 34 * y ** 2 - 36) * x + 36 * y ** 8 - 140 * y ** 6 + 196 * y ** 4 - 108 * y ** 2 + 4) * z / 2 + 2 * x ** 5 + (8 * y ** 2 - 11) * x ** 3 / 2 + (4 * y ** 4 - 11 * y ** 2 + 14) * x / 2)).Compile(True)
uex = proj * CoefficientFunction((-z*z,y,x))
pex = None
u, uhat, p, r = Vh.TrialFunction()
v, vhat, q, s = Vh.TestFunction()
uhat = uhat.Trace()
vhat = vhat.Trace()
tang = lambda v: v-(v*mu)*mu
gradu = proj * CoefficientFunction((grad(u),), dims = (3,3)).trans * proj # full gradient
gradv = proj * CoefficientFunction((grad(v),), dims = (3,3)).trans * proj # full gradient
epsu = 0.5 * (gradu + gradu.trans)
epsv = 0.5 * (gradv + gradv.trans)
print("Done with part 5")
a = BilinearForm(Vh, symmetric = True)
a += SymbolicBFI(InnerProduct(epsu,epsv), BND)
a += SymbolicBFI(-InnerProduct(epsu*mu, tang(v.Trace()-vhat)), BND, element_boundary = True)
a += SymbolicBFI(-InnerProduct(epsv*mu, tang(u.Trace()-uhat)), BND, element_boundary = True)
a += SymbolicBFI(gamma/h * InnerProduct(tang(v.Trace()-vhat), tang(u.Trace()-uhat)), BND, element_boundary = True)
a += SymbolicBFI(-div(u.Trace())*q.Trace(), BND)
a += SymbolicBFI(-div(v.Trace())*p.Trace(), BND)
a += SymbolicBFI(s.Trace()*p.Trace(), BND)
a += SymbolicBFI(r.Trace()*q.Trace(), BND)
print("Done with part 6")
f = LinearForm(Vh)
f += SymbolicLFI( proj * force * v.Trace(), BND, bonus_intorder = order_u)
if pex != None:
f += SymbolicLFI (s.Trace()*pex, BND)
print("Done with part 7")
print("Done with part 8")
print("Done with part 9")
gfu = GridFunction(Vh)
def SetFreeDofs(V):
for el in V.components[0].Elements(BBND):
for dofs in el.dofs:
V.FreeDofs().Clear(dofs)
V.FreeDofs(True).Clear(dofs)
for el in V.components[1].Elements(BBND):
V.FreeDofs().Clear(dofs+V.components[0].ndof)
V.FreeDofs(True).Clear(dofs+V.components[0].ndof)
print("Done with part 9.1")
SetFreeDofs(Vh)
print("Done with part 9.2")
#ainv = a.mat.Inverse(Vh.FreeDofs())
ainv = a.mat.Inverse(freedofs = Vh.FreeDofs(), inverse = "umfpack")
print("Done with part 10")
gfu.vec.data = ainv * f.vec
vel = gfu.components[0]
print("Done with part 11")
Draw(uex, mesh, 'uex')
Draw(vel, mesh, 'u')
Draw(Norm(uex), mesh, '|uex|')
Draw(Norm(vel), mesh, '|u|')
Draw(Norm(vel-uex), mesh, '|u-uex|')
Draw(force, mesh, "force")
print("Done with part 12")
print(sqrt(Integrate((uex - vel)**2, mesh, BND)))
print(sqrt(Integrate(uex**2, mesh, BND)))
print(sqrt(Integrate(vel**2, mesh, BND)))
5 years 5 hours ago #3319 by Bittermandeln
Solved it, it had to do with my meshing of the sphere
5 years 5 hours ago - 5 years 5 hours ago #3320 by plederer
Replied by plederer on topic H(div)-HDG on surfaces
Yes, I just wanted to mention this. Easy fix is to move the "from ngsolve import *" below the "from netgen import..." and use
mesh = Mesh(geo.GenerateMesh(perfstepsend=MeshingStep.MESHSURFACE,optsteps2d=3,maxh=0.3))
Best, Philip
Last edit: 5 years 5 hours ago by plederer.
