High RAM usage
4 years 9 months ago - 4 years 9 months ago #3304 by rgs
High RAM usage was created by rgs
I am trying to run what should be a fairly simple simulation. My code is given below:
from netgen.csg import * # Defining solid sphere=Sphere(Pnt(0,0,0),0.55).bc('FSI') pX=Plane(Pnt(0.5,0,0),Vec(1,0,0)) nX=Plane(Pnt(-0.5,0,0),Vec(-1,0,0)) pY=Plane(Pnt(0,0.5,0),Vec(0,1,0)) nY=Plane(Pnt(0,-0.5,0),Vec(0,-1,0)) pZ=Plane(Pnt(0,0,0.5),Vec(0,0,1)) nZ=Plane(Pnt(0,0,-0.5),Vec(0,0,-1)) Zielinski=sphere*pX*nX*pY*nY*pZ*nZ # Making geometry from solid geo=CSGeometry() geo.Add(Zielinski.mat("domain"), bcmod=[(pX,"xplus"),(nX,"xminus"),(pY,"yplus"),(nY,"yminus"),(pZ,"zplus"),(nZ,"zminus")]) # Marking periodic surfaces geo.PeriodicSurfaces(pX,nX) geo.PeriodicSurfaces(pY,nY) geo.PeriodicSurfaces(pZ,nZ) # Meshing from ngsolve.comp import Mesh netgenMesh=geo.GenerateMesh(maxh=0.05) mesh = Mesh(netgenMesh) # Converting netgen mesh to ngsolve mesh Draw (mesh) k = 3 velocityFiniteElementSpace = Periodic(VectorH1(mesh, order=k, dirichlet="FSI")) #discrete velocity space pressureFiniteElementSpace = Periodic(H1(mesh, order=(k-1), dirichlet="FSI")) #discrete pressure space productSpace = FESpace([velocityFiniteElementSpace,pressureFiniteElementSpace]) (trialFunction1,trialFunction2), (testFunction1,testFunction2) = productSpace.TnT() e = CoefficientFunction( (1,0,0) ) # conservative source flux in COMSOL LHS = BilinearForm(productSpace) LHS += (InnerProduct(grad(trialFunction1),grad(testFunction1))-div(trialFunction1)*testFunction2-div(testFunction1)*trialFunction2)*dx LHS.Assemble() RHS = LinearForm(productSpace) RHS += SymbolicLFI(e*testFunction1) RHS.Assemble() gfu = GridFunction(productSpace) inv = LHS.mat.Inverse(freedofs=productSpace.FreeDofs(), inverse="umfpack") res = RHS.vec.CreateVector() res.data = RHS.vec - LHS.mat*gfu.vec gfu.vec.data += inv * res Redraw() velocity = CoefficientFunction(gfu.components[0:2][0])
This is a modified version of the Stokes part of the Navier-Stokes tutorial ( ngsolve.org/docu/latest/i-tutorials/unit...es/navierstokes.html ). I am not trying to simulate a flow - this is a corollary for an acoustic problem.
The script runs, but if I increase the order (k) beyond 3 or if I decrease the element size any further, my workstation (which has 96GB RAM) runs out of memory and NGSolve closes with the message "Killed". I am able to run the same simulation with the same geometry on OpenFOAM without it requiring nearly as much RAM. I know that OpenFOAM uses FVM and so this is an apples to oranges comparison, but surely, the simulation shouldn't be taking so much RAM. Am I doing something wrong?
Last edit: 4 years 9 months ago by rgs.
4 years 9 months ago #3305 by christopher
Replied by christopher on topic High RAM usage
With order 3 you already have ~500k dofs on this mesh and direct solvers will get expensive. With order 4 you get ~1.1 mio dofs and a denser matrix . This is the region where you have to start using iterative methods.
You could save dofs and increase accuracy by curving the mesh though:
mesh.Curve(5)
4 years 9 months ago #3306 by rgs
Replied by rgs on topic High RAM usage
Thank you for your quick reply. What does Curve() do? Python help only says that it curves the elements.
Time to create page: 0.101 seconds
