Naming mesh boundaries
4 years 10 months ago #3293 by rgs
Naming mesh boundaries was created by rgs
Hello!
Is there a way to name mesh boundaries? The tutorial pages show how to name boundaries for geometries created using CSGeometry, but I don't see any similar options for imported geometries or meshes.
For instance, if I import an STL file with the following script:
from netgen.stl import * #from netgen.libngpy._stl import* geo = STLGeometry('netgenSTL_05.stl') geo.GenerateMesh()
The function STLGeometry does not have .bc() or .Add() functions like in CSGeometry.
Another question I have is, is there a difference between the libngpy and the normal versions of the modules?
Thank you in advance!
4 years 10 months ago #3295 by mneunteufel
Replied by mneunteufel on topic Naming mesh boundaries
the Netgen mesh class has the method SetBCName to name boundaries (0-based index) after you created a mesh from the geometry.
from ngsolve import * from netgen.geom2d import unit_square mesh = Mesh(unit_square.GenerateMesh(maxh=0.1)) print("before: ", mesh.GetBoundaries()) mesh.ngmesh.SetBCName(0,"newname") print("after : ", mesh.GetBoundaries())
4 years 9 months ago - 4 years 9 months ago #3303 by rgs
Replied by rgs on topic Naming mesh boundaries
Thank you!
I can set the boundary name for a particular boundary if I know the boundary index. Is there a way to set the names of boundaries that I do not know the indices of? I am looking for something like the bcmod argument of the Add() function in the following script:
from netgen.csg import * sphere=Sphere(Pnt(0,0,0),0.55).bc('FSI') pX=Plane(Pnt(0.5,0,0),Vec(1,0,0)) nX=Plane(Pnt(-0.5,0,0),Vec(-1,0,0)) pY=Plane(Pnt(0,0.5,0),Vec(0,1,0)) nY=Plane(Pnt(0,-0.5,0),Vec(0,-1,0)) pZ=Plane(Pnt(0,0,0.5),Vec(0,0,1)) nZ=Plane(Pnt(0,0,-0.5),Vec(0,0,-1)) Geom=sphere*pX*nX*pY*nY*pZ*nZ geo=CSGeometry() geo.Add(Geom.mat("domain"), bcmod=[(pX,"xplus"),(nX,"xminus"),(pY,"yplus"),(nY,"yminus"),(pZ,"zplus"),(nZ,"zminus")])
I would also be interested to know about any other ways we can specify which boundary we want to name.
Last edit: 4 years 9 months ago by rgs.
4 years 9 months ago - 4 years 9 months ago #3347 by rgs
I noticed that the ngsolve mesh class has a function Boundaries() which according to the Python documentation "Return(s) boundary mesh-region matching the given regex pattern" for the syntax "Boundaries(self: ngsolve.comp.Mesh, pattern: str)". Can someone please give me an example of a regular expression I can use in this function? Can this be used to find the boundary index of a surface?
Edit: I am aware that one possible regex is the name of the boundary
