Set Meshing Options with Python?
4 years 11 months ago #3275 by mariopa
I am new to Netget/NGSolve.
I hope you guys can help me, here the manual way I do:
I load a new Geometry into NGSolve.
After that I navigate into "Meshing options..." select "Mash granularity=very coarse" after that under "Mesh Size/Elements per curv...radius" I switch it to the value 5.
After that "Export Mesh" to a *.STL file.
that works fine, but I need to do this automaticly.
I allready wrote a little phyton file:
from netgen.NgOCC import *
geo = LoadOCCGeometry('Part.stp')
mesh = geo.GenerateMesh()
Draw(Mesh(mesh))
# mesh.Export('Part2.stl','STL Format')
But I do not have any idea how I can set the "meshing options" first?
Anyone can help?
thanks much,
regards, mario
4 years 11 months ago #3279 by mariopa
no one any idea?
4 years 11 months ago - 4 years 11 months ago #3280 by matthiash
Hi Mario,
There are arguments you can pass to the GenerateMesh() function to control the meshing algorithms. For your case, try the following code
from netgen.meshing import MeshingParameters, meshsize ... mesh = geo.GenerateMesh(meshsize.very_coarse, curvaturesafety=5) Draw(Mesh(mesh))
Last edit: 4 years 11 months ago by matthiash.
4 years 11 months ago #3281 by mariopa
thx much for your answer, but it does not generate a mesh:
Draw(Mesh(mesh))
it just shows me the Part.stp in the GUI, but not the generated mesh.
what wrong with this?
regards, mario
4 years 11 months ago #3283 by mariopa
This comes from the console:
NETGEN-6.2-dev
togl-version : 2
OCC module loaded
loading ngsolve library
NGSolve-6.2.1905
Using Lapack
Including sparse direct solver Pardiso
Running parallel using 6 thread(s)
importing NGSolve-6.2.1905
(should) load python file 'Skript.py'
load OCC geometry Number of colours in STEP File: 1
Colour [1] = STEELBLUE3 : (0.380392,0.576471,0.752941)
Highest entry in topology hierarchy:
1 solid(s)
File "<string>", line 4, in <module>
ImportError: cannot import name 'meshsize' from 'netgen.meshing' (C:\Program Files\ngsolve-v6.2.1905\lib\site-packages\netgen\meshing.py)
Finished executing Skript.py
Preparing visualization (deflection = 0.01) ... done
4 years 11 months ago #3284 by matthiash
Seems your version of NGSolve is outdated (19.05), I suggest you download a recent version. Note that you might also need to update Python to 3.7.
