Creating a mesh with different (sub)-domains
4 years 10 months ago - 4 years 10 months ago #3274 by bhaveshshrimali
Hi everyone,
I want to run a run a elasticity problem with two materials -- a matrix and two spherical solids embedded in it. I need a refined mesh between the spheres as I plan to extend the code to do phase-field fracture. For getting an idea of the geometry, consider something like the attached figure:
[attachment=undefined]trialGeometry.png[/attachment] [attachment=undefined]trialGeometry.jpg[/attachment] [attachment=undefined]trialGeometry.jpg[/attachment]
The problem is that I am getting stuck at the mesh generation part itself. I am using NGSolve-6.2.1909
Consider the following snippet:
import numpy as np from ngsolve import * from netgen.csg import * Do = 2.286e-3 Ho = 0.21 * Do H1 = Do - Ho/2. lo, bo, to = 4*Do, 2*Do, 2*Do eps = 5.e-6 # do two refinements left = Plane(Pnt(0,0,0), Vec(-1,0,0)) bottom = Plane(Pnt(0,0,0), Vec(0,-1,0)) back = Plane(Pnt(0,0,0), Vec(0,0,-1)) right = Plane(Pnt(lo,0,0), Vec(1,0,0)) top = Plane(Pnt(0,bo,0), Vec(0,1,0)) front = Plane(Pnt(0,0,to), Vec(0,0,1)) box = left * right * bottom * top * back * front inleft = Plane(Pnt(H1 + Do/2., Do/2., Do/2.), Vec(-1,0,0)) inbottom = Plane(Pnt(H1 + Do/2., Do/2., Do/2.), Vec(0,-1,0)) inback = Plane(Pnt(H1 + Do/2., Do/2., Do/2.), Vec(0,0,-1)) inright = Plane(Pnt(H1 + 1.5 * Do + Ho, Do/2., Do/2.), Vec(1,0,0)) intop = Plane(Pnt(H1 + Do/2., 3.*Do/2., Do/2.), Vec(0,1,0)) infront = Plane(Pnt(H1 + Do/2., Do/2., 3.*Do/2.), Vec(0,0,1)) inbox = inleft * inright * inbottom * intop * inback * infront spheres = [ Sphere(Pnt(H1 + Do/2., Do, Do), Do/2.), Sphere(Pnt(H1 +1.5 * Do + Ho, Do, Do), Do/2.), ] Spheres = spheres[0] + spheres[1] geo = CSGeometry() matrix = box - Spheres innerpdms = inbox - Spheres outerpdms = matrix - innerpdms # onlyspheres = box * Spheres geo.Add(outerpdms) geo.Add(Spheres) geo.Add(innerpdms) outerpdms.maxh(10*eps) innerpdms.maxh(eps/3.) Spheres.maxh(10*eps) msh = geo.GenerateMesh(grading=0.8)
But this simply stalls at:
importing NGSolve-6.2.1909 Start Findpoints main-solids: 3 Found points 24 Analyze spec points Find edges
Would anyone have a clue as to what could be going wrong?
Thanks
Bhavesh
Last edit: 4 years 10 months ago by bhaveshshrimali. Reason: Image not visible
