Refining mesh - Stokes problem
4 years 10 months ago #3267 by Bittermandeln
I am working on the stationary Stokes problem. My advisor told me that the stability of Taylor-hood elements for the Stokes problem when using triangular elements requires that each element only has maximum one side on the boundary. Hence, we thought to use a large mesh that satisfies this, and then refine it. However, the error of the solution diverges with more refinements. Any idea's? The code is found below.
Alvar
# basic xfem functionality
from numpy import pi
import scipy
import scipy.sparse as sp
geo.AddRectangle( (0, 0), (1, 1), bcs = ("top", "left", "bottom", "right"))
#uex = CoefficientFunction((2*pi*sin(pi*x)**2*cos(pi*y)*sin(pi*y), -2*pi*sin(pi*x)*cos(pi*x)*sin(pi*y)**2))
#force = CoefficientFunction((12*pi**3*sin(pi*x)**2*sin(pi*y)*cos(pi*y) - pi*sin(pi*x)*cos(pi*y) - 4*pi**3*sin(pi*y)*cos(pi*x)**2*cos(pi*y),-12*pi**3*sin(pi*x)*sin(pi*y)**2*cos(pi*x) + 4*pi**3*sin(pi*x)*cos(pi*x)*cos(pi*y)**2 - pi*sin(pi*y)*cos(pi*x)))
#pex = CoefficientFunction(cos(pi*x)*cos(pi*y))
nu = 1
#uex = CoefficientFunction((sin(pi*y), -cos(pi*x)))
#force = CoefficientFunction((-pi*sin(pi*x)*cos(pi*y) + nu * pi**2*sin(pi*y), -pi*sin(pi*y)*cos(pi*x) - nu * pi**2*cos(pi*x)))
#uex = CoefficientFunction((sin(y) + cos(y), 0))
#force = CoefficientFunction((sin(y) + cos(y) + cos(x),0))
#pex = sin(x)
uex = CoefficientFunction((y*(1-y), 0))
force = CoefficientFunction((3,0))
pex = CoefficientFunction(x-1/2)
l22_list = []
l2p_list = []
def my_abs(mesh, v, h0):
a = 0
x = np.arange(0,1+h0, h0)
for i in range(len(x)):
for j in range(len(x)):
p1 = np.array([x])
p2 = np.array([x[j]])
mip = mesh(p1, p2)
val = abs(v(mip))
a = max(a, val)
return a
def l2error(refinement = 0, structured = False, quad = False):
order = 2
alpha = 10
h0 = 0.3
if structured:
mesh = Mesh(geo.GenerateMesh(maxh = h0, quad_dominated = quad))
for i in range(refinement):
#Draw(mesh)
mesh = Mesh(geo.GenerateMesh(maxh = h0*2**(-refinement), quad_dominated = quad))
#Wh = HDiv(mesh, order = order+1, dgjumps = True, BDM = True) #Velocity space
Wh = VectorH1(mesh, order = order, dgjumps = True) #Velocity space
Qh = L2(mesh, order = order-1) #Pressure space
Nh = NumberSpace(mesh) #Lagrange multiplier
Vh = FESpace([Wh,Qh,Nh], dgjumps = True)
u,p,r = Vh.TrialFunction()
v,q,s = Vh.TestFunction()
tang = lambda v:v #If no tangential projections are wanted
#tang = lambda v: v-(v*n)*n #If tangential projections are wanted
jump_u = tang(u-u.Other())
jump_v = tang(v-v.Other())
flux_u = 0.5*(grad(u) + grad(u.Other()))*n
flux_v = 0.5*(grad(v) + grad(v.Other()))*n
a = BilinearForm(Vh)
#Volume integrals
a += SymbolicBFI(nu*InnerProduct(grad(u), grad(v)))
a += SymbolicBFI(-div(u)*q) #consistent symmetrizing term
a += SymbolicBFI(-div(v)*p)
a += SymbolicBFI(p*s)
a += SymbolicBFI(q*r)
#Interior facet integrals
a += SymbolicBFI(-nu*InnerProduct(flux_u,jump_v), VOL, skeleton = True)
a += SymbolicBFI(-nu*InnerProduct(flux_v,jump_u), VOL, skeleton = True) #consistent symmetrizing term
a += SymbolicBFI(h**(-1) * alpha * order**2 * InnerProduct(jump_u,jump_v), VOL, skeleton=True) #consistent stabilizing term
#Boundary facet integrals
a += SymbolicBFI(-nu*InnerProduct(Grad(u)*n,tang(v)), BND, skeleton = True)
a += SymbolicBFI(-nu*InnerProduct(Grad(v)*n,tang(u)), BND, skeleton = True) #symmetrizing term
a += SymbolicBFI(h**(-1) * alpha * order**2 * InnerProduct(tang(u),tang(v)), BND, skeleton=True) #stabilizing term
a += SymbolicBFI(v*n*p, BND, skeleton=True)
a += SymbolicBFI(u*n*q, BND, skeleton=True) #symmetrizing term
#Right-hand side
f = LinearForm(Vh)
f += SymbolicLFI(force*v)
f += SymbolicLFI(-nu*InnerProduct(Grad(v)*n,uex),BND, skeleton = True) #symmetrizing term
f += SymbolicLFI(h**(-1) * alpha * order**2 * InnerProduct(uex,v), BND, skeleton=True) #stabilizing term
f += SymbolicLFI(uex*n*q, BND, skeleton = True) #symmetrizing term
f += SymbolicLFI(pex*s)
gfu = GridFunction(Vh)
gfuex = GridFunction(Wh)
gfuex.Set(uex)
gfpex = GridFunction(Qh)
gfpex.Set(pex)
a_inv = a.mat.Inverse(freedofs = Vh.FreeDofs(), inverse="umfpack")
gfu.vec.data = a_inv*f.vec
vel = gfu.components[0]
pres = gfu.components[1]
#Draw(pres, mesh, "p")
#Draw(vel, mesh, "u")
#Draw(div(vel), mesh, "div(u)")
#Draw(Norm(vel), mesh, "|u|")
dv = grad(vel)
dg = grad(gfuex)
divu = div(vel)
#eu = sum((dv-dg)**2)
eu = (vel - gfuex)**2
ep = (pres - gfpex)**2
err = vel-gfuex
Draw(Norm(err), mesh, "|e|")
l22 = Integrate(eu, mesh)
l2p = Integrate(ep, mesh)
l22_list.append(l22)
l2p_list.append(l2p)
print("\nRefinement level ", refinement)
print("L2 error in velocity: ", sqrt(l22))
print("L2 error in pressure: ", sqrt(l2p))
print("div(u)-norm", Integrate(divu**2, mesh))
if len(l22_list)>1:
print("EOCu: ", (np.log(sqrt(l22_list[-2]))-(np.log(sqrt(l22_list[-1]))))/np.log(2))
print("EOCp: ", (np.log(sqrt(l2p_list[-2]))-(np.log(sqrt(l2p_list[-1]))))/np.log(2))
for i in range(3,4):
l2error(i, structured = True, quad = False)
4 years 10 months ago #3269 by Bittermandeln
I have solved it, I had to switch from L2 to H1(dgjumps=true) in the pressure space. But why should this be needed? Isnt L2-space same as H1(dgjumps=true)?
4 years 10 months ago #3270 by joachim
It's not - just look at fes.ndof
The following user(s) said Thank You: Bittermandeln
4 years 10 months ago #3272 by schruste
The dgjumps=True does not change your FESpace. It only changes the non-zero entries to be reserved in the matrix. In NGSolve the sparsity pattern is set up before the actual assembling of the element entries. Typically, the sparsity is precomputed based on overlapping support of basis functions. If two basis functions have support on the same element, a non-zero entry is reserved in the sparse matrix. For DG-type couplings this is however not enough. If you are on a facet and want to involve all functions of the two adjacent elements, some of these may not overlap, but may still interact due to some jump/derivative-interaction. To make sure to increase the sparsity pattern we introduced the dgjumps-Flag. If it is set to true all basis functions that are linked (through the neighboring volume element) to the same facet, get a non-zero entry now.
I hope that helps (and that I didn't forget to discuss some corner cases...).
So, L2 is not the same as H1(dgjumps=True). However, L2 is the same as Discontinuous(H1), but this is a different story...
4 years 10 months ago #3273 by Bittermandeln
Thank you for your help. I will stay away from L2 in the future :)
