Generating Finite Element Space with FESpace
- elizabethmonte
5 years 2 weeks ago #3263
by elizabethmonte
Generating Finite Element Space with FESpace was created by elizabethmonte
I'm trying to use FESpace to construct finite element spaces. However, for certain types of elements I get an error of the sort NgException: undefined fespace 'H1'. I've attached a script with a basic test and I only seem to be able to use FESpace for VectorH1 and VectorL2 elements.
Are certain types of finite element space only available from the generator functions directly?
5 years 2 weeks ago #3265
Replied by joachim on topic Generating Finite Element Space with FESpace
Hi Elizabeth,
the old, internal name of the fespaces (as used ngs.FESpace(fes_type, ..)) is not the same as the Python class name.
You can figure out the typename as follows:
It gives you 'h1ho'.
Alternatively, you can create an object of the python class given as string via
fes = ngs.H1(mesh, order=3)
print (fes.type)
fes = getattr(ngs, fes_type) (mesh, order=3)
- elizabethmonte
5 years 2 weeks ago #3266
by elizabethmonte
Replied by elizabethmonte on topic Generating Finite Element Space with FESpace
I see, thank you! That works perfectly.
