If I want use function space of tensor?
5 years 2 weeks ago #3207 by yhhan
If I need the function space of vector, I can use VectorL2(mesh, order). But if I need the function space of tensor, what I should use?
Another question is that when we solve saddle point problem, like Stokes problem, the matrix is indefinite, how the solve it? what command can we use?
thanks
5 years 2 weeks ago #3208 by mneunteufel
Hi yhhan,
there is currently no MatrixL2 space direktly available. However, you can "construct" it by
MatrixL2 = L2(mesh, order=order, dim=4) u,v = MatrixL2.TnT() u.dims = (2,2) v.dims = (2,2) gf = GridFunction(MatrixL2) gf.dims = (2,2)
For a saddle point problem you can use direct solvers as umfpack or also the build-in sparsecholesky solver if you regularize the problem at the lower-right zero block. E.g. for Stokes involving velocity u and pressure p you can add
a += -1e-9*p*q
as regularization.
5 years 2 weeks ago #3209 by joachim
a short note on the solver for saddle point problems:
you can easily use MinRes or GMRes with block-preconditioning, see e.g.
ngsolve.org/docu/latest/i-tutorials/unit-2.6-stokes/stokes.html
as a starting point.
5 years 2 weeks ago #3210 by yhhan
Hi Michael,
Thank you so much, I will try it.
best,
Yihui
5 years 2 weeks ago #3211 by yhhan
Hi Joachim,
I will check it later, thank you for your help.
best,
Yihui
5 years 2 weeks ago #3212 by yhhan
Hi Michael,
For vector space, I can use V=VectorL2(mesh, order = ), then in the following
u.dims = (2,2)
v.dims = (2,2)
gf.dims = (2,2)
which one is like the above space V written by me? It seems that MatrixL2 = L2(mesh, order=order, dim=4) is different from the space V.
Yihui
