Saturated BH curve
7 years 6 months ago #461 by RENXiaotao
I am solving nonlinear Eddy Current Problem. The Iron reluctivity nu dependents on the flux density norm B0.
Without saturation:
nu =CoefficientFunction([3.8*exp(2.17*B0*B0)+396.2 if mat== "magnet" else 1.0/(1.0*mu0)
for mat in mesh.GetMaterials()])
The magnetization curve saturates, e.g., at 1.8 T. How to set this?
Thanks,
Xiaotao
I try this:
def nuf(B0):
if B0 >=1.8:
return 3.8*exp(2.17*1.8*1.8)+396.2
return 3.8*exp(2.17*B0*B0)+396.2
nu =CoefficientFunction([nuf(B0) if mat== "inner" else 1.0/(1.0*mu0)
# TypeError '>=' not supported between instances of 'ngsolve.fem.CoefficientFunction' and 'float'
Here is B0.
mesh is 2D
fes = HCurl(mesh, order=2, dirichlet="b|r|t|l", nograds=True)
gfu.Set(...) # gfu is an in-plane vector
B0=curl(gfu) # B0 has one component
7 years 6 months ago #462 by bernd
Replied by bernd on topic Saturated BH curve
Hi Xiaotao,
I think the "IfPos" function might help you. It checks if a CoefficientFunction is positive at the evaluation points. It is documented here .
By transforming "B0 >= 1.8" to "B0-1.8 >= 0", we can write the definition for the `nuf` function as:
def nuf(B0): return IfPos(B0 - 1.8, 3.8*exp(2.17*1.8*1.8)+396.2, 3.8*exp(2.17*B0*B0)+396.2)
The following user(s) said Thank You: RENXiaotao
7 years 5 months ago #463 by RENXiaotao
Replied by RENXiaotao on topic Saturated BH curve
Thank you, Bernd.
Now the function nuf works perfectly well.
