CalcElementVector - macOS RuntimeError: std::bad_cast
- creativeworker
- Senior Member
5 years 1 week ago #3110
by creativeworker
I use the following code-snippet without any problems on windows.
On macOS (installation via conda) Python 3.7.3, ngsolve 6.2.2007 it fails with RuntimeError: std::bad_cast.
I use H1 elements for fes. Anyone a tip where this difference between macOS and Windows could be relevant for this function?
With kind regards,
for el in fes.Elements(VOL):
elvec = f_int_lfi.CalcElementVector (el.GetFE(), el.GetTrafo())
With kind regards,
5 years 1 week ago #3113
Replied by joachim on topic CalcElementVector - macOS RuntimeError: std::bad_cast
without seeing the full code it's difficult to say whether windows of macOS are right. I am not aware of an essential difference.
- creativeworker
- Senior Member
5 years 1 week ago - 5 years 1 week ago #3122
by creativeworker
Replied by creativeworker on topic CalcElementVector - macOS RuntimeError: std::bad_cast
I see your point. Up to now I was not able to generate a minimal example that has the same issue. It seems that the function el.GetTrafo() throws the error: *** RuntimeError: std::bad_cast.
Last edit: 5 years 1 week ago by creativeworker. Reason: refining the question.
- creativeworker
- Senior Member
5 years 1 week ago #3123
by creativeworker
I now found a perfect minimal example to show the behavior. The attached file runs fine on windows and fails on macOS.
It seems to have something to do with the SetDeformation command on the mesh.
Perhaps this helps you to check what could go wrong here.
5 years 1 day ago #3135
fixed in the latest nightly release,
thanks for the report,
Time to create page: 0.149 seconds
