Compiler and gcc version
5 years 1 month ago - 5 years 1 month ago #3089
by raymond
Compiler and gcc version was created by raymond
On my cluster I only have access to GCC 7.3 or 8.2.
Compiling ngsolve with gcc 8.2 seems to be unsupported. Compiling ngsolve with 7.3 gives me the following errors
Any advice on how to build ngsolve using either of these gcc versions?
[ 30%] Building CXX object fem/CMakeFiles/ngfem.dir/diffop_grad.cpp.o
/home/janwdp/ngsuite/ngsolve-src/fem/diffop_grad.cpp: In static member function ‘static std::shared_ptr<ngfem::CoefficientFunction> ngfem::DiffOpGradientBoundary<D, FEL>::DiffShape(std::shared_ptr<ngfem::CoefficientFunction>, std::shared_ptr<ngfem::CoefficientFunction>) [with int D = 2; FEL = ngfem::ScalarFiniteElement<1>]’:
/home/janwdp/ngsuite/ngsolve-src/fem/diffop_grad.cpp:24:23: internal compiler error: in assign_temp, at function.c:968
n -> SetDimensions( Array<int> ( { dim, 1 } ) );
0x91e471 assign_temp(tree_node*, int, int)
../../gcc/function.c:968
0x7e0a6f initialize_argument_information
../../gcc/calls.c:1825
0x7e0a6f expand_call(tree_node*, rtx_def*, int)
../../gcc/calls.c:3278
0x8d3abd expand_expr_real_1(tree_node*, rtx_def*, machine_mode, expand_modifier, rtx_def**, bool)
../../gcc/expr.c:10889
0x7f0226 expand_expr
../../gcc/expr.h:276
0x7f0226 expand_call_stmt
../../gcc/cfgexpand.c:2658
0x7f0226 expand_gimple_stmt_1
../../gcc/cfgexpand.c:3571
../../gcc/cfgexpand.c:3737
0x7f110f expand_gimple_basic_block
../../gcc/cfgexpand.c:5744
0x7f6276 execute
../../gcc/cfgexpand.c:6357
Please submit a full bug report,
with preprocessed source if appropriate.
Please include the complete backtrace with any bug report.
See <https://gcc.gnu.org/bugs/> for instructions.
make[5]: *** [fem/CMakeFiles/ngfem.dir/diffop_grad.cpp.o] Error 1
make[4]: *** [fem/CMakeFiles/ngfem.dir/all] Error 2
make[3]: *** [all] Error 2
make: *** [all] Error 2
Last edit: 5 years 1 month ago by raymond.
5 years 1 month ago #3090
Replied by christopher on topic Compiler and gcc version
gcc 8.2 has a critical bug affecting NGSolve, and it seems like gcc 7.3 also...
You can try to change this line of code to
and see if it compiles.
If not, you can either ask your admins to update to recent compiler versions or compile a recent version yourself and use it.
Array<int> a({dim, 1});
n -> SetDimensions(a)
