- Thank you received: 1
'SIMD: don't know how I shall evaluate in Assemble BilinearForm' error
5 years 1 month ago - 5 years 1 month ago #3042
by dong
I used the solution of a problem to be an input of another problem.
When I tried with an exact solution (a CoefficientFunction), the code worked well.
When I tried with an computed solution (a GridFunctioN), there is an error as follows.
The error was disappeared when I deleted line 248 (But I need this line in the discrete formulation.):
So I guess the error maybe come from u.
Please see the attached file for details.
Can I convert a gridfunction to a similar form of a coefficient function? Could you please tell me how to fix that error?
Thank you so much.
NgException: GridFunctionCoefficientFunction: SIMD: don't know how I shall evaluatein Assemble BilinearForm 'biform_from_py'
a += (u*n)*wbar.Trace()*cbar.Trace()*ds
Thank you so much.
Last edit: 5 years 1 month ago by dong.
- mneunteufel
- Premium Member
- Thank you received: 59
5 years 1 month ago #3043
by mneunteufel
Replied by mneunteufel on topic 'SIMD: don't know how I shall evaluate in Assemble BilinearForm' error
Hi dong,
u is a VectorL2 GridFunction, which you want to evaluate at the boundary.
L2 (and therefore VectorL2) has no well defined Trace (the L2 space returns a "DummyFE" which seems to cause an exception).
Further, in the definition of the space
the dirichlet flag will be ignored (the number of dofs and number of free dofs coincide).
V1 = VectorL2(mesh, order=order, dirichlet="gammaS|gammaD")
The following user(s) said Thank You: dong
