- Thank you received: 24
Pickling Segmentation Fault/ Inconsistent behaviour
5 years 1 month ago #2988
by hvwahl
Pickling Segmentation Fault/ Inconsistent behaviour was created by hvwahl
Hi everyone,
to restart a simulation I'm using data pickled in a previous run. To ensure that the meshes are the same, I take a copy of the mesh from a pickled GridFunction. Using this copy a create new FESpace and a new GridFunction into which I copy the data from the pickled GridFunction.
When I try to pickle this new grid function I sometimes get a segmentation fault. Attached is a MWE (run once with 'restart=False' and then with 'True').
Can anyone help me to avoid these segmentation faults?
Best wishes,
Henry
PS: This inconsistency is both on mac an linux, self build on commits gee9a66d1 and gac4d9b1f (NGSolve 2006).
Best wishes,
Henry
5 years 1 month ago #2989
by hvwahl
Replied by hvwahl on topic Pickling Segmentation Fault/ Inconsistent behaviour
Update:
The issue seems to stem from the fact that I delete the unpickled GridFunction. I thought this would not be problematic, since I explicitly copy the mesh
Is there a better way to copy the mesh?
Best wishes,
Henry
mesh = Mesh(_gfu_pic.space.mesh.ngmesh.Copy())
Best wishes,
Henry
5 years 1 month ago #2990
by matthiash
Replied by matthiash on topic Pickling Segmentation Fault/ Inconsistent behaviour
Hi Henry,
Thanks for the report and the update. We are on it and already found the issue (it's about pointers in the netgen::Mesh, which are not correctly set in the copy). The fix will be on master soon.
5 years 1 month ago #2991
by hvwahl
Hi Matthias,
thank for the quick reply and fix
Best wishes,
Henry
Best wishes,
Henry
