using functions for CoefficientFunction
5 years 3 months ago #2972
by sm22
using functions for CoefficientFunction was created by sm22
Hello NGSolve,
I need to use a coefficient function that depends on the spatial coordinates. I tried the following:
But the class can not be an argument for the CoefficientFunction. How to incorporate slightly involved functions such as the one above to be used in bilinear form? Thank you!!
#!/usr/bin/env python
# coding: utf-8
# initialise mpi
comm = mpi_world
rank = comm.rank
nproc= comm.size
fes = H1(mesh, complex=True, order=2)
u = fes.TrialFunction()
v = fes.TestFunction()
R=0.8
class myCoeff:
def __init__(self):
self.R = R
def eval(self, value, x):
outside = ( x >= R )
coeff = 1. / (x - R)
value = outside * coeff
C = CoefficientFunction(myCoeff)
# want to use a coefficient in the bilinear form:
# a = BilinearForm (fes, symmetric=True)
# a += SymbolicBFI (C*grad(u)*grad(v))
- mneunteufel
- Premium Member
- Thank you received: 59
5 years 3 months ago #2974
by mneunteufel
Replied by mneunteufel on topic using functions for CoefficientFunction
Hi sm22,
the IfPos CoefficientFunction should work
see also the documentation for CoefficientFunctions . If you need a fancy CoefficientFunction which is not available there is the possibility to define your own CoefficientFunction in C++ and then to export it to Python, see this link .
IfPos(x-R,1/(x-R),0)
