any suggestions to speed up explicit DG updates?
5 years 2 months ago #2909 by Guosheng Fu
Dear all,
I have attached a demo code for incompressible two phase flow using hybrid-mixed FEM (RT0) for pressure and DG-P0 for saturation.
Currently, I use the standard DG updates for the saturation conservation law equation.
I believe this default version could be significantly improved, but I don't know what's the best option available now in ngsolve. I would like to get ideas about speeding up this code. Many thanks as always!
Guosheng
5 years 2 months ago #2923 by mneunteufel
Hi Guosheng,
I tried to modify your ForwardEuler by replacing the Matrix-Vector multiplication, but this did not really help.
def ForwardEuler(sh, dt): rhsS.data = aS.mat * sh #rhsS.data = invm*rhsS fesS.SolveM(rhsS) return sh-dt*rhsS
Also to "inline" it did not bring a lot
#gfuS.vec.data = ForwardEuler(gfuS.vec, dt) aS.Apply(gfuS.vec,rhsS) gfuS.vec.data -= dt*invm*rhsS
However, the Compile flag made a huge difference! It is important to compile everything, not only a part of it
if kdg>0: aS += (-uh*fw(ss)*grad(tt)).Compile(true_compile, wait=True)*dx ... aS += (uh*n*Fhat*tt).Compile(true_compile, wait=True)*dx(element_boundary=True)
With this I got a speed up of a factor 3!
It is also possible to speed up your "fast" part even more. Instead of calling mat.Invert every time you can "update" the inverse:
a.Assemble() inv = a.mat.Inverse(fesP.FreeDofs(True),inverse="sparsecholesky") while time < tend-dt/2 : if stepS%nsubcycles == 0: a.Assemble() inv.Update() ... gfuP.vec.data = inv * rhsP
Then the symbolic factorization is done only once and not every step. This improved the "fast" part from 2.4 to 1.5 seconds on my machine.
5 years 2 months ago #2925 by Guosheng Fu
Hi Michael,
Thanks about the two tricks, they are helpful.
I also get roughly a factor of 3 speedup with the correct use of the Compile flag, and a factor of 2 for the sparse Cholesky inverse update.
Changing element_boundary formulation to skeleton-based formulation further helps to speed-up the explicit DG solver slightly.
I am now thinking about using implicit DG solver for saturation. But Newton solver fails since .Other() only works for proxyfunctions, not gridfunctions. Do you have any suggestions on this issue?
Guosheng
