- Thank you received: 1
'ngsolve.comp.SumOfIntegrals' object has no attribute 'SetDefinedOnElements'
5 years 3 months ago #2760
by dong
The attached file come from
this diccusion
with a small change.
The part that I changed is:
In many example on the forum, a+=something*dx is used to define a bilinear form for a weak formulation instead of using SymbolicBFI. I think they are interchangeable, so I guessed the above code can be rewrite as in the following one.
Then, there is an error when I run the file.
I'm just wondering if there is any way to code in the second way, which is equivalent to the first one such that the original code works.
Many thanks in advanced.
interfacebfi = SymbolicBFI (cf1+cf2+cf3, VOL, skeleton=True )
interfacebfi.SetDefinedOnElements(interface_indicator)
a += interfacebfi
interfacebfi = (cf1+cf2+cf3)*dx(skeleton=True )
a += interfacebfi
AttributeError: 'ngsolve.comp.SumOfIntegrals' object has no attribute 'SetDefinedOnElements'
5 years 3 months ago #2809
Replied by christopher on topic 'ngsolve.comp.SumOfIntegrals' object has no attribute 'SetDefinedOnElements'
you are right, this was missing.
It is added in the current master and nightly and next release builds.
There you can use
There you can use
... * dx(definedonelements=bitarray)
The following user(s) said Thank You: dong
