Preconditioners for Maxwells Equation
5 years 5 months ago #2664 by Elsakori
I am using NGSolve to solve Maxwell’s equations in time-harmonic form.
The problem that I work on is B=curl(u) * curl(v)+beta*u*v. I use the first order Nedelec space V for the approximate solution and use an auxiliary subspace W of the Nedelec space (W =span {second order face basis+third order volume basis) for computing the error function ‘’ e’’.
I print the condition numbers of the stiffness matrices on V and W. The code produce results for beta>0 and for small negative values of beta, e.g. {-10^(-4), -10^(-2) ,-10}, but with big negative values of beta like -10^(2) or -10^(4) the code gives the error
Eigensystem: Preconditioner negative
File "<string>", line 195, in <module>
File "<string>", line 127, in SolveBVP
ValueError: max() arg is an empty sequence
I am not quite familiar with using Preconditioners, I tried using different types of them but still have the same error. I am not sure which type of them work fine with my problem.
I am grateful for any explanation or help.
Ahmed
Here is my python script.
5 years 5 months ago - 5 years 5 months ago #2672 by lkogler
Hello Ahmed,
The function "Eigenvalues_Preconditioner" computes Eigenvalues of the the generalized EVP
[tex]
A x = \lambda C x
[/tex]
For SPD (or hermitian) matrices A and C.
When beta is positive (or not too negative), your matrix is SPD. When it is not, it also has negative eigenvalues, and Eigenvalues_Preconditioner does not work. This does not say anything about how good those preconditioners are, just that you cannot use Eigenvalues_Preconditioner to get the Eigenvalues.
NGSolve has the "ArnoldiSolver" to solve such problems, but afaik both matrices A and C have to be given as sparse matrices, which is not the case if C is (the inverse of) a preconditioner. Besides that I do not know if there is a built-in solver that can compute these Eigenvalues.
For large, negative lambda, I am not sure which preconditioners work well.
I believe "bddc" works if your mesh is fine enough, but will have to invert a relatively large problem directly.
"multigrid" should work as long as the coarsest mesh is fine enough, in which case it also requires you to solve a relatively large problem directly.
Lukas
Last edit: 5 years 5 months ago by lkogler.
