Meshing Fails for Scaled Sheet
5 years 6 months ago #2535 by valhan
Hi everybody!
I have tried to mesh a sheet.
First I mesh it in meters, than in decimeters, than in centimeters and finally in millimeters.
It is quite simple in my opinion, however it does not work properly.
Meter, dm, cm work fine but mm fails.
What do I do wrong?
Cheers, Valentin
from netgen.csg import * def foo(scale = 1): thickness = 0.18 origin = Pnt(0, 0, 0) corner = Pnt(9*scale, 4*scale, thickness*scale) left = Plane (origin, Vec(-1,0,0) ) right = Plane (corner, Vec( 1,0,0) ) front = Plane (origin, Vec(0,-1,0) ) back = Plane (corner, Vec(0, 1,0) ) bot = Plane (origin, Vec(0,0,-1) ) top = Plane (corner, Vec(0,0, 1) ) cube = left * right * front * back * bot * top geo = CSGeometry() geo.Add (cube) mesh = geo.GenerateMesh(maxh=1) mesh.Save("cube.vol") if __name__ == "__main__": from ngsolve import * ngsglobals.msg_level = 0 print("it works with scale 1:") foo(1) print("it works with scale 0.1:") foo(0.1) print("it works with scale 0.01:") foo(0.01) print("it does not work with scale 0.001:") foo(0.001) # from ngsolve import * # mesh = Mesh("cube.vol") # import netgen.gui # Draw(mesh) print("done") # input()
5 years 6 months ago #2537 by valhan
Thanks to the information in the (personal) replies, I was able to fix the issue.
One suggested work-around would be to use the non-scaled model and fit the other parameters.
The proper solution redefines the bounding box of the mesh generator by
geo.SetBoundingBox(Pnt(-10*scale, -10*scale, -10*scale), Pnt(10*scale, 10*scale, 10*scale))
Under consideration of this adaption the original code works fine:
from netgen.csg import * def foo(scale = 1): thickness = 0.18 origin = Pnt(0, 0, 0) corner = Pnt(9*scale, 4*scale, thickness*scale) left = Plane (origin, Vec(-1,0,0) ) right = Plane (corner, Vec( 1,0,0) ) front = Plane (origin, Vec(0,-1,0) ) back = Plane (corner, Vec(0, 1,0) ) bot = Plane (origin, Vec(0,0,-1) ) top = Plane (corner, Vec(0,0, 1) ) cube = left * right * front * back * bot * top geo = CSGeometry() geo.Add (cube) geo.SetBoundingBox(Pnt(-10*scale, -10*scale, -10*scale), Pnt(10*scale, 10*scale, 10*scale)) mesh = geo.GenerateMesh(maxh=1) mesh.Save("cube.vol") if __name__ == "__main__": from ngsolve import * ngsglobals.msg_level = 0 print("it works with scale 1:") foo(1) print("it works with scale 0.1:") foo(0.1) print("it works with scale 0.01:") foo(0.01) print("it does not work with scale 0.001:") foo(0.001) # from ngsolve import * # mesh = Mesh("cube.vol") # import netgen.gui # Draw(mesh) print("done") # input()
