Building the NGS-Suite and ngsxfem together
5 years 5 months ago #2507
by nepomuk
Building the NGS-Suite and ngsxfem together was created by nepomuk
I'm quite a newby to Linux (using Ubuntu 19.10) and had some troubles while installing NGS and xfem together. I did the following (sudo where necessary):
and got the following response:
I attached the CMakeOutput.log
What went wrong - what should I do? Thanks a lot for the help!
cd usr/share
git clone https://github.com/ngsxfem/ngsxfem.git
cd ngsxfem
mkdir build
git submodule update --init
cd build
cmake ../ -DCMAKE_INSTALL_PREFIX=/usr/share -DBUILD_NGSOLVE=ON
[ 81%] Building CXX object comp/CMakeFiles/ngcomp.dir/pde.cpp.o
/usr/share/ngsxfem/external_dependencies/ngsolve/comp/pde.cpp:8:10: fatal error: tcl.h: Datei oder Verzeichnis nicht gefunden
8 | #include <tcl.h>
compilation terminated.
make[5]: *** [comp/CMakeFiles/ngcomp.dir/build.make:479: comp/CMakeFiles/ngcomp.dir/pde.cpp.o] Fehler 1
make[4]: *** [CMakeFiles/Makefile2:507: comp/CMakeFiles/ngcomp.dir/all] Fehler 2
make[3]: *** [Makefile:141: all] Fehler 2
make[2]: *** [CMakeFiles/ngsolve.dir/build.make:116: dependencies/Stamp/ngsolve/ngsolve-build] Fehler 2
make[1]: *** [CMakeFiles/Makefile2:222: CMakeFiles/ngsolve.dir/all] Fehler 2
make: *** [Makefile:152: all] Fehler 2
[ 30%] Built target netgen_project
[ 61%] Built target ngfem
[ 61%] Building CXX object comp/CMakeFiles/ngcomp.dir/pde.cpp.o
CMake Error at CMakeLists.txt:91 (find_package):
Could not find a package configuration file provided by "NGSolve" with any
of the following names:
NGSolveConfig.cmake
ngsolve-config.cmake
Add the installation prefix of "NGSolve" to CMAKE_PREFIX_PATH or set
"NGSolve_DIR" to a directory containing one of the above files. If
"NGSolve" provides a separate development package or SDK, be sure it has
been installed.
-- Configuring incomplete, errors occurred!
See also "/usr/share/ngsxfem/build/CMakeFiles/CMakeOutput.log".
5 years 5 months ago #2508
by schruste
Replied by schruste on topic Building the NGS-Suite and ngsxfem together
Hi nepomuk,
To build from sources you require a few libraries, see ngsolve.org/docu/latest/install/installlinux.html
You should do the following first:
sudo apt-get update && sudo apt-get -y install python3 python3-tk libpython3-dev libxmu-dev tk-dev tcl-dev cmake git g++ libglu1-mesa-dev liblapacke-dev
Furthermore as installation location you should use /usr instead of /usr/share. Even better is to use a user local installation.
5 years 5 months ago #2509
by nepomuk
Replied by nepomuk on topic Building the NGS-Suite and ngsxfem together
Hi Christoph,
thanks for your quick reply.
So I first did the commands you told me, then I cloned ngsxfem to /home/nepomuk. Should I do also the other steps performed at ngsolve.org/docu/latest/install/installlinux.html first, or can I proceed with the cmake command?
Best, Nepomuk
Best, Nepomuk
5 years 5 months ago #2510
by schruste
ngsxfem builds ngsolve, so you can directly step to the cmake command. However, the section "Finishing the installation" is again relevant to make use of the local installation once the installation was successful.
Good luck,
Good luck,
5 years 5 months ago #2511
by nepomuk
Hi Christoph,
doing the cmake command (what took a lot of time as the other times I tried) it hanged up again and threw an error at the same point I describe in my first post.
Trying to do the make command anyway didn't work.
What went wrong?
BR, Nepomuk
What went wrong?
BR, Nepomuk
5 years 5 months ago #2512
by schruste
I don't really know. As it is a problem already appearing in the NGSolve-part of the installation, I recommend you try to install ngsolve from scratch first (without xfem) and only afterwards try to involve ngsxfem.
Alternatively, you can also install ngsolve binaries on ubuntu, see ngsolve.org/downloads . Check if the corresponding ngsolve installation works. If yes, try to build ngsxfem, but this time with BUILD_NGSOLVE=OFF .
Time to create page: 0.154 seconds
