reading physical groups gmsh mesh file in NGSolve (mpi build)
5 years 7 months ago #2494
by gcdiwan
Dear NGSolve developers;
I'm trying to read a mesh file generated using GMSh, the geo file reads:
While the mesh generated with the above geo file using:
and then reading it using:
The mesh file read goes through in the NGSolve installed on my linux PC (NGSolve-6.2.1909). However, the same piece of code and mesh fails to read when i use NGSolve on cluster (mpi build). Since I am using GMsh to define my physical surfaces as well as volumes, i am not sure if i need to do anything additional to define the face descriptors as mentioned in another post here .
What do you think could be the source of the problem? Thank you!
ps. I hope everyone is keeping safe amidst the current outbreak of covid19.
Mesh.CharacteristicLengthExtendFromBoundary = 0;
Mesh.CharacteristicLengthFromPoints = 0;
Mesh.CharacteristicLengthFromCurvature = 0;
Mesh.CharacteristicLengthMax = helem;
Merge "Geom.STEP";
Physical Surface("plane6_geomA") = {6};
Physical Surface("plane8_geomB") = {8};
Physical Surface("plane7_geomC") = {7};
Point(90001) = {0, -43.150, 0, 1.0};
Physical Surface("other_geom_srf") = {4, 9, 14, 1, 10, 3, 11, 2, 15, 17, 16, 5, 12, 13};
Merge "sphere.geo";
Surface Loop(30002) = {13, 1, 5, 11, 2, 8, 10, 3, 7, 9, 4, 6, 12};
Surface Loop(30003) = {16, 14, 15, 17};
Volume(40002) = {30001, 30002, 30003};
Physical Surface("sphere_srf") += {20025, 20019, 20023, 20021, 20027, 20029, 20015, 20017};
Physical Volume("air") = {40002};
subprocess.call(["gmsh", "-v", "0", "-3", "-setnumber", "helem", str(helem), "-setnumber", "R1", str(radcomp), str(basegeofilename), "-o", str(meshfilename)])
if (rank==0):
mesh = ReadGmsh(meshfilename)
if (nproc > 1):
mesh.Distribute(comm)
mesh = netgen.meshing.Mesh.Receive(comm)
5 years 6 months ago #2500
by lkogler
Replied by lkogler on topic reading physical groups gmsh mesh file in NGSolve (mpi build)
I have never worked with gmesh before and I am not sure wether it should work with MPI or not. Could you send me a complete example file, then I can maybe figure out if the problem is something simple or something major.
Lukas
Lukas
