Stop meshing since boundary mesh is overlapping
5 years 6 months ago - 5 years 6 months ago #2448 by bhaveshshrimali
I am trying to mesh a unit cube containing several randomly distributed spherical inclusions. Since the cube is triply periodic (along `x`, `y` and `z`) I create matching spheres on the faces/edges to be able to generate a mesh with matching pairs of vertices.
I am currently running two cases:
1. Not including the spheres (basically meshing `cube - all_spheres` object). This runs fine and produces a matching mesh as desired.
2. Including the spheres. In this case I get the error, " Stop meshing since boundary mesh is overlapping ". I am assuming that it could arise from the spheres on two faces not being exactly mirrored. But then why would case 1. run perfectly fine? Any suggestions?
I am attaching the portion of the code that generates the mesh
def generateGmshMesh(xc, pc, rc): """ docstring """ left = Plane(Pnt(0,0,0),Vec(-1,0,0)) bottom = Plane(Pnt(0,0,0),Vec(0,-1,0)) back = Plane(Pnt(0,0,0),Vec(0,0,-1)) right = Plane(Pnt(1,0,0),Vec(1,0,0)) top = Plane(Pnt(0,1,0),Vec(0,1,0)) front = Plane(Pnt(0,0,1),Vec(0,0,1)) cube = left * right * bottom * top * back * front all_spheres = [Sphere(Pnt(sph[0], sph[1], sph[2]), rc[i]) for i, sph in enumerate(xc)] all_particles = [Sphere(Pnt(sph[0], sph[1], sph[2]), rc[i]) for i, sph in enumerate(pc)] for i, sph in enumerate(all_spheres): if i==0: sphAll = all_spheres[i] else: sphAll += all_spheres[i] for i, sph in enumerate(all_particles): if i==0: partAll = all_particles[i] else: partAll += all_particles[i] # reduce(operator.mul, all_spheres) # partAll = reduce(operator.mul, all_particles, 1) matrix = cube - sphAll partsinCube = cube * partAll matrix.maxh(0.01) partsinCube.maxh(0.005) matrix.transp() partsinCube.col([1,0,0]) matrix.mat("mat") partsinCube.mat("parts") geo = CSGeometry() geo.Add(matrix) geo.Add(partsinCube) geo.PeriodicSurfaces(left,right) geo.PeriodicSurfaces(bottom,top) geo.PeriodicSurfaces(back,front) geo.Draw() Redraw() msh = geo.GenerateMesh() msh.Export("trialMesh.msh", "Gmsh2 Format") msh.Export("trialMesh.inp", "Abaqus Format")
I tried playing with the `maxh` paramter but to no avail.
Last edit: 5 years 6 months ago by bhaveshshrimali.
5 years 6 months ago #2451 by christopher
could you attach the calling code as well?
5 years 6 months ago - 5 years 6 months ago #2453 by bhaveshshrimali
Hi Christopher,
Thanks for your reply. Here is the calling code:
rad = np.loadtxt("radii_10.txt") sph = np.loadtxt("spheres_10.txt") generateGmshMesh(sph, sph, rad)
Note that if I do
rad = np.loadtxt("radii_10.txt") sph = np.loadtxt("spheres_10.txt") generateGmshMesh(sph,[], rad)
and comment out the relevant lines in the function, it generates the mesh as desired. The microstructure looks something like this. The spheres are close but non-intersecting, and the unit cell (cube with spheres) is periodic by construction.
File Attachment:
File Name: spheres_10...3-02.txt
File Size:12 KB
File Attachment:
File Name: radii_10_2...3-02.txt
File Size:4 KB
