Help with Example Electrostatics Model
5 years 6 months ago #2555 by mneunteufel
Hi jleman,
if I load the saved mesh in python via
mesh = Mesh('dome.vol')
all boundaries seem to be saved and loaded properly.
With
for v in mesh.vertices: print(v.point)
you get all mesh points.
If you solve the problem in NGSolve and assume your solution is saved in the GridFunction gfu then you can access data at a point p=(p_x, p_y, p_z) by
value = gfu(mesh(p_x,p_y,p_z))
If you have a CoefficientFunction Q representing the charge density you can get values on the surface by
value = Q(mesh(p_x,p_y,p_z, BND))
Of course the point must be a surface point on the mesh.
If you have the equations by hand I would recommend doing everything in NGSolve via Python.
The following user(s) said Thank You: jleman
3 years 3 weeks ago #4501 by Yash.sooriya
Hello mneunteufel,
I was wondering if you still have access to this dome.py file or you remember how to do this, as it would be very helpful for my current project. Thanks!
3 years 2 weeks ago #4504 by christopher
This code snippet should solve this problem:
from netgen.occ import * from ngsolve import * air = Sphere((0,0,0), 1) air.faces.name = "air" ground = HalfSpace((0,0,0), (0,0,-1)) ground.faces.name = "ground" box = Box((-0.1,-0.1,-0.1), (0.1,0.1,0.1)) box.faces.name = "volt" box.faces.maxh = 0.02 domain = (air * ground) - box geo = OCCGeometry(domain) mesh = Mesh(geo.GenerateMesh(maxh=0.2)) mesh.Curve(3) Draw(mesh) fes = H1(mesh, order=3, dirichlet="ground|volt") u,v = fes.TnT() eps = 1 a = BilinearForm(fes) a += eps * grad(u) * grad(v) * dx u = GridFunction(fes) with TaskManager():     r = u.vec.CreateVector()     a.Assemble()     u.Set(1, definedon=mesh.Boundaries("volt"))     r.data = - a.mat * u.vec     u.vec.data += a.mat.Inverse(fes.FreeDofs()) * r     Draw(u, mesh, "potential")     Draw(-grad(u), mesh, "E")
