Tagging (sub)meshes for separate top level objects
- bhaveshshrimali
- Junior Member
5 years 6 months ago #2389
by bhaveshshrimali
I have a 3D mesh generated from a `.geo` file with two `TopLevelObjects`. These are to be assigned different materials. Basically, something like
I generate the mesh as follows:
Is it possible to extract the corresponding meshes for each "TopLevelObject" (namely parts and matrix) and assign them physical tags them before exporting to gmsh. I need to eventually export the mesh in `dolfin` `xdmf` format. Since that is not naively supported, I want to export the mesh to gmsh-format and then manually convert it to dolfin xdmf (using meshio).
Thanks in advance!
algrbraic3d
solid p1=plane (0,0,0;0,0,-1);
solid p2=plane (1,1,1;0,0,1);
solid p3=plane (0,0,0;0,-1,0);
solid p4=plane (1,1,1;0,1,0);
solid p5=plane (0,0,0;-1,0,0);
solid p6=plane (1,1,1;1,0,0);
solid cube=p1 and p2 and p3 and p4 and p5 and p6;
solid sph = sphere(0.5, 0.5, 0.5; 0.1);
solid matrix=cube and not sph;
solid part = cube and sph
tlo matrix -transparent;
tlo parts -col=[1,0,0];
identify periodic p1 p2;
identify periodic p3 p4;
identify periodic p5 p6;
geo = CSGeometry("Cube_Sphere.geo")
msh = geo.GenerateMesh(maxh=0.05)
msh.Export("AbaqusMesh.inp", "Abaqus Format") #this creates separate 'parts'
msh.Export("Gmsh_mesh.msh", "Gmsh2 Format") #this does not create separate physical tags
Thanks in advance!
5 years 6 months ago #2391
Replied by christopher on topic Tagging (sub)meshes for separate top level objects
not sure, but I think, every volume domain (toplevelobject) corresponds to a physical group in the gmsh mesh afterwards. The index is 100000+element index in Netgen.
Note Netgen does only support exporting to an old gmsh v2 file format. Maybe that is the problem?
- bhaveshshrimali
- Junior Member
5 years 6 months ago #2394
by bhaveshshrimali
Replied by bhaveshshrimali on topic Tagging (sub)meshes for separate top level objects
Thanks for your reply Christopher. I would try to manually write the gmsh file and see.
