Partition mesh for VTKOutput
- BenWilson94
- Junior Member
5 years 8 months ago #2382
by BenWilson94
Partition mesh for VTKOutput was created by BenWilson94
I am currently simulating an Eddy current problem consisting of a small conducting object in a large domain and I wish to export the solution using the VTKOutput function. Is there a way in which to 'partition' the mesh to use the Multi-block Inspector feature in ParaView, so that only the object and surrounding field lines can be seen?
Kind regards,
Ben
Kind regards,
Ben
5 years 8 months ago #2383
by schruste
Replied by schruste on topic Partition mesh for VTKOutput
Dear Ben,
I have no experience with the multi-block inspector feature and wouldn't know where this feature needs to be put for the VTK-format.
But what you can do is, export a field that assumes different values on different objects, e.g. with DomainConstantCoefficientFunction, i.e. CoefficientFunction([1,2,3,4,5]) . Afterwards you can use ParaViews filters to select only certain objects...
The following user(s) said Thank You: BenWilson94
- BenWilson94
- Junior Member
5 years 8 months ago #2384
by BenWilson94
Replied by BenWilson94 on topic Partition mesh for VTKOutput
Dear Christoph,
That's excellent. Thank you very much.
Kind regards,
Ben
Kind regards,
Ben
