Defining subdomains in a periodic mesh
- camilo.suarezafanador
5 years 8 months ago #2369
by camilo.suarezafanador
Defining subdomains in a periodic mesh was created by camilo.suarezafanador
dear Colleagues
I would like to know if someone has already worked with subdomains in a L2 periodic mesh, I am trying to set a unite square cell with a circle inclusion but is not working the material definition, thanks by advance for your help.
Camilo.
Camilo.
5 years 8 months ago #2392
Replied by christopher on topic Defining subdomains in a periodic mesh
What do you mean with not working? Do you have an example code that is failing? Without inclusion it is working?
5 years 8 months ago #2393
Replied by camilo.suarezafanador on topic Defining subdomains in a periodic mesh
Thanks Christopher
First, yes the code is running without inclusion.
It seem the subdomains are not being recognized after adding the circle to the periodic square, when I call the them with mesh.GetMaterials is shows: KeyError: 'default'
I don't know if could be the definition of periodic.SetMaterial .... or the definitions in left-right domain. Thank you so much by advance for your help.
Best regards
# Creating Geometry
# Unite cell set-up
l = 1
ST = l*l
vf = 0.2
Sf = vf*ST
r = sqrt(Sf/pi)
# Creating Periodic Geometry
periodic = SplineGeometry()
pnts = [ (-0.5*l,-0.5*l), (0.5*l,-0.5*l), (0.5*l,0.5*l), (-0.5*l,0.5*l) ]
pnums = [periodic.AppendPoint(*p) for p in pnts]
lright = periodic.Append ( ["line", pnums[1], pnums[2]], bc="periodicx")
lsup = periodic.Append ( ["line", pnums[2], pnums[3]],bc="periodicy")
periodic.Append ( ["line", pnums[0], pnums[3]], leftdomain=0, rightdomain=1, copy=lright, bc="periodicx")
periodic.Append ( ["line", pnums[1], pnums[0]], leftdomain=0, rightdomain=1, copy=lsup, bc="periodicy")
periodic.AddCircle(c=(0,0), r=r, bc="circle", leftdomain=2, rightdomain=1)
mesh = Mesh(periodic.GenerateMesh(maxh=0.1, quad_dominated=False))
order = 2
periodic.SetMaterial (1, "outer")
periodic.SetMaterial (2, "inner")
domain_values = {'inner': -1, 'outer': 1}
values_list = [domain_values[mat]
for mat in mesh.GetMaterials()]
Best regards
5 years 7 months ago #2404
You need to set the materials before creating the mesh.
The following user(s) said Thank You: camilo.suarezafanador
5 years 7 months ago #2407
You're right, my bad
, thanks for your time Christopher
best regards
Camilo
best regards
Camilo
