Error L^2 norm for FESpace([V,F])
6 years 1 week ago - 6 years 1 week ago #1953 by Amad
Dear,
I've been working with NGSolve solving time harmonic elastic wave problem, with Robin boundary condition.
I am solving this problem using classical Galerkin and Hybrid Discontinuous Galerkin.
For the Galerkin method, it is working fine and the error in L2 norm is around 10^(-5).
For the HDG method, the solution seems correct (visually similar to the Galerkin method) but the L2 norm is not convergent.
For the HDG method, I choose the following spaces
V = VectorH1(mesh, order=order, complex=True) F = VectorH1(mesh, order=order, complex=True) fes = FESpace([V,F])
To compute the L2 norm, I am using the following code
u = CoefficientFunction(gfu.components[0]) #Error analysis print ("Displacement L2-error:", sqrt (Integrate ( (u-uexact)*Conj(u-uexact), mesh)))
If I try to compute the norm using the following code, I get an error ("NgException: CompoundFESpace does not have an evaluator for VOL!")
gmesh = GridFunction(fes) gmesh.Set(uexact) u_exact = CoefficientFunction(gmesh) u = CoefficientFunction(gfu.components[0]) print ("Displacement L2-error:", sqrt (Integrate ( (u-u_exact)*Conj(u-u_exact), mesh)))
How to compute the error in L^2 norm in fes = FESpace([V,F]) space?
Last edit: 6 years 1 week ago by Amad.
6 years 5 days ago #1954 by mneunteufel
Dear Amad,
it is not possible to Set a Compound FESpace with one line
Setting each component individually
gmesh = GridFunction(fes) gmesh.components[0].Set(uexact) u = gfu.components[0] print ("Displacement L2-error:", sqrt (Integrate ( (u-u_exact)*Conj(u-u_exact), mesh)))
should work.
Are you sure that for HDG your Facetvariable should also live in a VectorH1 space?
Normally you want to have the dofs only on the facets like described here:
HDG tutorial
Maybe you'll need to make a Compound FESpace of three FacetFeSpaces.
The following user(s) said Thank You: Amad
6 years 5 days ago - 6 years 5 days ago #1958 by Amad
Hi Michael,
Thank you for the prompt reply.
You are right, the chosen space was wrong.
But, I am facing a problem with the formulation.
As I am solving a vector problem, I need to choose a vector space. If I choose
V = VectorL2(mesh, order=order, complex=True) F = VectorL2(mesh, order=order, complex=True) fes = FESpace([V,F],dgjumps=True)
For the bilinear form
def epsilon(u): return 0.5 * (u.Deriv().trans + u.Deriv()) def sigma(u): return lamb*Trace(epsilon(u))*Id(mesh.dim) + 2*mu*epsilon(u) a = BilinearForm(fes, condense=condense) dS = dx(element_boundary=True) a += InnerProduct(sigma(u), epsilon(v)) * dx - rho * omega**2 * InnerProduct(u, v) * dx +\ beta*InnerProduct(jump_u,jump_v) * dS +\ -InnerProduct(sigma(u)*n, jump_v) * dS - InnerProduct(sigma(v)*n, jump_u) * dS a += -1j*matA*uhat.Trace()*vhat.Trace() * ds
Then, I got the following error: "NgException: don't have a trace, primal evaluator = FN5ngfem6DiffOpINS_16DiffOpIdVectorH1ILi2ELNS_4VorBE0EEEEEvE"
If I choose the following spaces
V = VectorL2(mesh, order=order, complex=True) F = FacetFESpace(mesh, order=order, complex=True) fes = FESpace([V,F],dgjumps=True) jump_u = u-uhat jump_v = v-vhat
I got the error: "NgException: Dimensions don't match, op = - dims1 = 0: 2, dims2 = 0: 1"
Is it possible to choose a vector space for FacetFESpace?
Thank you in advance.
Last edit: 6 years 5 days ago by Amad.
6 years 5 days ago #1963 by mneunteufel
Dear Amad,
you need to define 2 FacetFESpaces in 2D as the FacetFESpace is just a scalar. This explains the exception.
You can "construct" a VectorFacetSpace in the following way:
V = VectorL2(mesh, order=order, complex=True) F = FacetFESpace(mesh, order=order, complex=True) fes = FESpace([V,F,F],dgjumps=True) (u,uhatx,uhaty), (v,vhatx,vhaty) = fes.TnT() uhat = CoeffiecientFunction( (uhatx,uhaty) ) vhat = CoeffiecientFunction( (vhatx,vhaty) ) jump_u = u-uhat jump_v = v-vhat
6 years 4 days ago #1964 by Amad
Dear Michael,
Thank you for the reply.
Now there is no dimension problem. But, in the boundary terms, I had a problem.
It not recognise the uhat.Trace(), vhat.Trace().
Here is the bilinear form
And below is the error I got:
--------------------------------------------------------------------------- AttributeError Traceback (most recent call last) <ipython-input-22-195408db1c27> in <module>() 26 dS = dx(element_boundary=True) 27 a += InnerProduct(sigma(u), epsilon(v)) * dx - rho * omega**2 *InnerProduct(u, v) * dx + beta*InnerProduct(jump_u,jump_v) * dS + -InnerProduct(sigma(u)*n, jump_v) * dS - InnerProduct(sigma(v)*n, jump_u) * dS ---> 28 a += -1j*matA*uhat.Trace()*vhat.Trace() * ds 29 30 f = LinearForm(fes) AttributeError: 'ngsolve.fem.CoefficientFunction' object has no attribute 'Trace'
6 years 4 days ago #1965 by mneunteufel
Hi Amad,
the exception explains that CoeffiientFunctions do not have a trace. Only test- and trialfunctions do have a trace operator defined. You need to construct it by yourself by
uhat = CoeffiecientFunction( (uhatx,uhaty) ) vhat = CoeffiecientFunction( (vhatx,vhaty) ) uhat_tr = CoeffiecientFunction( (uhatx.Trace(),uhaty.Trace()) ) vhat_tr = CoeffiecientFunction( (vhatx.Trace(),vhaty.Trace()) ) ... a += -1j*matA*uhat_tr*vhat_tr* ds
