How to turn off screen printing when executing "GenerateMesh"?
6 years 3 weeks ago #1891
by MA
How to turn off screen printing when executing "GenerateMesh"? was created by MA
I'm using "netgen" to mesh a 3D surface. Could you please let me know how to turn off the print to screen when running:
mesh = geo.GenerateMesh(maxh=maxh/scale)
Thanks.
MA
Example:
set global mesh
Start Findpoints
main-solids: 1
Found points 0
Analyze spec points
done
find points done
Find edges
Add line segment to smooth surface
0 edges found
Check intersecting edges
CalcLocalH: 2 Points 0 Elements 0 Surface Elements
Start Findpoints
main-solids: 1
Found points 0
Analyze spec points
done
Find edges
0 edges found
Start Findpoints
main-solids: 1
Found points 0
Analyze spec points
done
Find edges
0 edges found
Surface 1 / 1
load internal triangle rules
Surface meshing done
Optimize Surface
126 elements, 65 points
SplitSeparateFaces
Check subdomain 1 / 1
126 open elements
Meshing subdomain 1 of 1
126 open elements
Use internal rules
126 open elements
Delaunay meshing
number of points: 65
blockfill local h
number of points: 66
Elements: 284
0 open elements
Num open: 0
free: 0, fixed: 284
SwapImprove
0 swaps performed
0 open elements
Num open: 0
free: 0, fixed: 284
SwapImprove
0 swaps performed
0 degenerated elements removed
Remove intersecting
Remove outer
tables filled
outer removed
126 open elements
66 points, 126 elements
0 open elements
0 open faces
start tetmeshing
Use internal rules
0 open elements
Success !
Remove Illegal Elements
0 illegal tets
Volume Optimization
CombineImprove
0 elements combined
ImproveMesh
Total badness = 240.426
Total badness = 235.863
SplitImprove
badmax = 5.48658
0 splits performed
ImproveMesh
SwapImprove
0 swaps performed
SwapImprove2
0 swaps performed
ImproveMesh
CombineImprove
0 elements combined
ImproveMesh
SplitImprove
badmax = 5.48658
0 splits performed
ImproveMesh
SwapImprove
0 swaps performed
SwapImprove2
0 swaps performed
ImproveMesh
CombineImprove
0 elements combined
ImproveMesh
SplitImprove
badmax = 5.48658
0 splits performed
ImproveMesh
SwapImprove
0 swaps performed
SwapImprove2
0 swaps performed
ImproveMesh
Thanks.
MA
Example:
set global mesh
Start Findpoints
main-solids: 1
Found points 0
Analyze spec points
done
find points done
Find edges
0 edges found
Start Findpoints
main-solids: 1
Found points 0
Analyze spec points
done
Find edges
0 edges found
Start Findpoints
main-solids: 1
Found points 0
Analyze spec points
done
Find edges
0 edges found
Surface 1 / 1
Optimize Surface
SplitSeparateFaces
126 open elements
126 open elements
Use internal rules
126 open elements
Delaunay meshing
blockfill local h
Elements: 284
0 open elements
Num open: 0
free: 0, fixed: 284
SwapImprove
0 swaps performed
0 open elements
Num open: 0
free: 0, fixed: 284
SwapImprove
0 swaps performed
Remove intersecting
Remove outer
tables filled
outer removed
126 open elements
0 open elements
0 open faces
start tetmeshing
Use internal rules
0 open elements
Success !
0 illegal tets
Volume Optimization
CombineImprove
0 elements combined
ImproveMesh
SplitImprove
badmax = 5.48658
0 splits performed
ImproveMesh
SwapImprove
0 swaps performed
SwapImprove2
0 swaps performed
ImproveMesh
CombineImprove
0 elements combined
ImproveMesh
SplitImprove
badmax = 5.48658
0 splits performed
ImproveMesh
SwapImprove
0 swaps performed
SwapImprove2
0 swaps performed
ImproveMesh
CombineImprove
0 elements combined
ImproveMesh
SplitImprove
badmax = 5.48658
0 splits performed
ImproveMesh
SwapImprove
0 swaps performed
SwapImprove2
0 swaps performed
ImproveMesh
6 years 3 weeks ago #1893
by MA
Replied by MA on topic How to turn off screen printing when executing "GenerateMesh"?
Sorry for the duplicate posting. This topic is related to:
ngsolve.org/forum/ngspy-forum/855-stop-t...console-message#1843
6 years 3 weeks ago #1895
Replied by christopher on topic How to turn off screen printing when executing "GenerateMesh"?
it should be enough to set
from ngsolve import ngsglobals
ngsglobals.msg_level = 0
6 years 3 weeks ago #1896
by MA
Thanks Christopher.
Is it possible to set the logger level when I'm only using "netgen" and not "ngsolve"?
Thank you.
MA
Thank you.
MA
6 years 3 weeks ago #1903
by MA
Is there a way to set the "printmessage_importance" level for the whole "netgen" module on Python?
Thanks,
MA
Thanks,
MA
6 years 3 weeks ago #1905
There is the function SetMessageImportance in netgen.meshing.
Best Christopher
Best Christopher
The following user(s) said Thank You: MA
