- Thank you received: 3
Error importing netgen.gui
6 years 9 months ago - 6 years 9 months ago #1298
by ddrake
Error importing netgen.gui was created by ddrake
I rebuilt NGsolve/Netgen from source yesterday on Ubuntu with no errors, but I got the following runtime error when importing netgen.gui:
In [2]: import netgen.gui
TclError Traceback (most recent call last)
<ipython-input-2-8534bccab7e0> in <module>()
----> 1 import netgen.gui
~/ngsuite/ngsolve-install/lib/python3/dist-packages/netgen/gui.py in <module>()
20
21 if not netgen.libngpy._meshing._netgen_executable_started:
---> 22 StartGUI()
~/ngsuite/ngsolve-install/lib/python3/dist-packages/netgen/gui.py in StartGUI()
9 win.tk.eval('lappend ::auto_path ' + netgen._netgen_bin_dir)
10 # load with absolute path to avoid issues on MacOS
---> 11 win.tk.eval('load "'+netgen._netgen_lib_dir.replace('\\','/')+'/libgui[info sharedlibextension]" gui')
12 win.tk.eval( netgen.libngpy._meshing._ngscript)
13
TclError: couldn't load file "/home/dow/ngsuite/ngsolve-install/lib/libgui.so": /home/dow/ngsuite/ngsolve-install/lib/libgui.so: undefined symbol: XmuLookupStandardColormap
I was thinking it might have something to do with this commit yesterday
Thanks!
Dow
20
---> 22 StartGUI()
13
Thanks!
Dow
Last edit: 6 years 9 months ago by ddrake.
6 years 9 months ago #1299
by matthiash
Replied by matthiash on topic Error importing netgen.gui
Hi Dow,
Which Ubuntu version are you using?
It is probably connected to to the commit you mentioned (and others before it that touched the build system). Please post the output of
and the contents of
Thanks,
ldd /home/dow/ngsuite/ngsolve-install/lib/libgui.so
/home/dow/ngsuite/ngsolve-build/netgen/netgen/CMakeCache.txt
Thanks,
6 years 9 months ago #1300
by ddrake
Replied by ddrake on topic Error importing netgen.gui
Hi Matthias,
It's actually Linux Mint 18.2 so it corresponds to Ubuntu 16.04.
$ ldd /home/dow/ngsuite/ngsolve-install/lib/libgui.so
linux-vdso.so.1 => (0x00007ffcc69d9000)
libnglib.so => /home/dow/ngsuite/ngsolve-install/lib/libnglib.so (0x00007fc0eddee000)
libtcl8.6.so => /usr/lib/x86_64-linux-gnu/libtcl8.6.so (0x00007fc0eda3f000)
libtk8.6.so => /usr/lib/x86_64-linux-gnu/libtk8.6.so (0x00007fc0ed6e2000)
libstlvis.so => /home/dow/ngsuite/ngsolve-install/lib/libstlvis.so (0x00007fc0ed4bf000)
libgeom2dvis.so => /home/dow/ngsuite/ngsolve-install/lib/libgeom2dvis.so (0x00007fc0ed2bb000)
libinterface.so => /home/dow/ngsuite/ngsolve-install/lib/libinterface.so (0x00007fc0ed064000)
libgeom2d.so => /home/dow/ngsuite/ngsolve-install/lib/libgeom2d.so (0x00007fc0ece23000)
libstl.so => /home/dow/ngsuite/ngsolve-install/lib/libstl.so (0x00007fc0ecb9e000)
libcsgvis.so => /home/dow/ngsuite/ngsolve-install/lib/libcsgvis.so (0x00007fc0ec97d000)
libcsg.so => /home/dow/ngsuite/ngsolve-install/lib/libcsg.so (0x00007fc0ec67d000)
libmesh.so => /home/dow/ngsuite/ngsolve-install/lib/libmesh.so (0x00007fc0ec194000)
libvisual.so => /home/dow/ngsuite/ngsolve-install/lib/libvisual.so (0x00007fc0ebf39000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007fc0ebd35000)
libGL.so.1 => /usr/lib/x86_64-linux-gnu/mesa/libGL.so.1 (0x00007fc0ebac1000)
libGLU.so.1 => /usr/lib/x86_64-linux-gnu/libGLU.so.1 (0x00007fc0eb852000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007fc0eb4c6000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007fc0eb1bd000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007fc0eafa5000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007fc0eabdb000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007fc0ea9be000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007fc0ea7a4000)
libXft.so.2 => /usr/lib/x86_64-linux-gnu/libXft.so.2 (0x00007fc0ea58f000)
libfontconfig.so.1 => /usr/lib/x86_64-linux-gnu/libfontconfig.so.1 (0x00007fc0ea34c000)
libX11.so.6 => /usr/lib/x86_64-linux-gnu/libX11.so.6 (0x00007fc0ea012000)
libXss.so.1 => /usr/lib/x86_64-linux-gnu/libXss.so.1 (0x00007fc0e9e0e000)
libpython3.5m.so.1.0 => /usr/lib/x86_64-linux-gnu/libpython3.5m.so.1.0 (0x00007fc0e9787000)
/lib64/ld-linux-x86-64.so.2 (0x00007fc0ee23b000)
libexpat.so.1 => /lib/x86_64-linux-gnu/libexpat.so.1 (0x00007fc0e955e000)
libxcb-dri3.so.0 => /usr/lib/x86_64-linux-gnu/libxcb-dri3.so.0 (0x00007fc0e935b000)
libxcb-present.so.0 => /usr/lib/x86_64-linux-gnu/libxcb-present.so.0 (0x00007fc0e9158000)
libxcb-sync.so.1 => /usr/lib/x86_64-linux-gnu/libxcb-sync.so.1 (0x00007fc0e8f51000)
libxshmfence.so.1 => /usr/lib/x86_64-linux-gnu/libxshmfence.so.1 (0x00007fc0e8d4e000)
libglapi.so.0 => /usr/lib/x86_64-linux-gnu/libglapi.so.0 (0x00007fc0e8b1d000)
libXext.so.6 => /usr/lib/x86_64-linux-gnu/libXext.so.6 (0x00007fc0e890b000)
libXdamage.so.1 => /usr/lib/x86_64-linux-gnu/libXdamage.so.1 (0x00007fc0e8708000)
libXfixes.so.3 => /usr/lib/x86_64-linux-gnu/libXfixes.so.3 (0x00007fc0e8502000)
libX11-xcb.so.1 => /usr/lib/x86_64-linux-gnu/libX11-xcb.so.1 (0x00007fc0e8300000)
libxcb-glx.so.0 => /usr/lib/x86_64-linux-gnu/libxcb-glx.so.0 (0x00007fc0e80e7000)
libxcb-dri2.so.0 => /usr/lib/x86_64-linux-gnu/libxcb-dri2.so.0 (0x00007fc0e7ee2000)
libxcb.so.1 => /usr/lib/x86_64-linux-gnu/libxcb.so.1 (0x00007fc0e7cc0000)
libXxf86vm.so.1 => /usr/lib/x86_64-linux-gnu/libXxf86vm.so.1 (0x00007fc0e7aba000)
libdrm.so.2 => /usr/lib/x86_64-linux-gnu/libdrm.so.2 (0x00007fc0e78a8000)
libfreetype.so.6 => /usr/lib/x86_64-linux-gnu/libfreetype.so.6 (0x00007fc0e75fe000)
libXrender.so.1 => /usr/lib/x86_64-linux-gnu/libXrender.so.1 (0x00007fc0e73f4000)
libutil.so.1 => /lib/x86_64-linux-gnu/libutil.so.1 (0x00007fc0e71f1000)
libXau.so.6 => /usr/lib/x86_64-linux-gnu/libXau.so.6 (0x00007fc0e6fed000)
libXdmcp.so.6 => /usr/lib/x86_64-linux-gnu/libXdmcp.so.6 (0x00007fc0e6de7000)
libpng12.so.0 => /lib/x86_64-linux-gnu/libpng12.so.0 (0x00007fc0e6bc2000)
I attached /home/dow/ngsuite/ngsolve-build/netgen/netgen/CMakeCache.txt
Dow
Dow
6 years 9 months ago #1301
by matthiash
That's strange, libgui.so should to X11_Xmu_LIB (in your case /usr/lib/x86_64-linux-gnu/libXmu.so), as stated in external_dependencies/netgen/ng/CMakeLists.txt:28
Please check that
target_link_libraries( gui PRIVATE ${ZLIB_LIBRARIES} ${JPEG_LIBRARIES} ${FFMPEG_LIBRARIES} ${X11_Xmu_LIB} ${X11_X11_LIB} ${OCC_LIBRARIES} ${LIBTOGL} )
Please check that
- the line above appears in ng/CMakeLists.txt (i.e. you have the latest source code of Netgen
- libgui.so is linked correctly, please check/attach
Code:your_build_dir/netgen/netgen/ng/CMakeFiles/gui.dir/link.txt
- There are no other versions of Netgen/NGSolve installed, check with
Code:python3 -c'import ngsolve; print(ngsolve.__file__)'
6 years 9 months ago #1302
by ddrake
Hi Matthias,
I'm working at home today so I don't have immediate access to the Linux mint machine, but I just did a full build from source on my Ubuntu 18.04.1 LTS machine and got the same error. I forgot to mention earlier, but on both machines I'm able to run netgen without any errors. The only error is on import netgen.gui from python3 or jupyter.
Here is the ldd output on this Ubuntu 18.04 machine:
Again we're not seeing a dependency on libXmu.so. I checked and that library is installed at the location you said: /usr/lib/x86_64-linux-gnu/libXmu.so
I do have the latest version of the source and the CMakeLists.txt is specifying X11_Xmu_Lib
Here are the contents of gui.dir/link.txt (which contain the -lXmu flag):
I only have one instance of NGSolve installed.
Before building this time, I deleted the entire ngsuite tree and then followed again the instructions to build from source on Linux. As I recall, I was able to build from source on both these machines about 3 weeks ago and did not see the error on import with that build.
Dow
$ netgen
NETGEN-6.2-dev
togl-version : 2
loading ngsolve library
NGSolve-6.2.1809-135-g9f2684ab
Using Lapack
Running parallel using 4 thread(s)
importing NGSolve-6.2.1809-135-g9f2684ab
Thank you for using NGSolve
linux-vdso.so.1 (0x00007ffc045fa000)
libnglib.so => /home/dow/ngsuite/ngsolve-install/lib/libnglib.so (0x00007f912c507000)
libtcl8.6.so => /usr/lib/x86_64-linux-gnu/libtcl8.6.so (0x00007f912c156000)
libtk8.6.so => /usr/lib/x86_64-linux-gnu/libtk8.6.so (0x00007f912bdfc000)
libstlvis.so => /home/dow/ngsuite/ngsolve-install/lib/libstlvis.so (0x00007f912bbd9000)
libgeom2dvis.so => /home/dow/ngsuite/ngsolve-install/lib/libgeom2dvis.so (0x00007f912b9d5000)
libinterface.so => /home/dow/ngsuite/ngsolve-install/lib/libinterface.so (0x00007f912b77e000)
libgeom2d.so => /home/dow/ngsuite/ngsolve-install/lib/libgeom2d.so (0x00007f912b53d000)
libstl.so => /home/dow/ngsuite/ngsolve-install/lib/libstl.so (0x00007f912b2b8000)
libcsgvis.so => /home/dow/ngsuite/ngsolve-install/lib/libcsgvis.so (0x00007f912b097000)
libcsg.so => /home/dow/ngsuite/ngsolve-install/lib/libcsg.so (0x00007f912ad96000)
libmesh.so => /home/dow/ngsuite/ngsolve-install/lib/libmesh.so (0x00007f912a8ac000)
libvisual.so => /home/dow/ngsuite/ngsolve-install/lib/libvisual.so (0x00007f912a651000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f912a44d000)
libGL.so.1 => /usr/lib/x86_64-linux-gnu/libGL.so.1 (0x00007f912a1c1000)
libGLU.so.1 => /usr/lib/x86_64-linux-gnu/libGLU.so.1 (0x00007f9129f52000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f9129bc9000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f912982b000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f9129613000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f9129222000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f9129003000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f9128de6000)
libXft.so.2 => /usr/lib/x86_64-linux-gnu/libXft.so.2 (0x00007f9128bd1000)
libfontconfig.so.1 => /usr/lib/x86_64-linux-gnu/libfontconfig.so.1 (0x00007f912898c000)
libX11.so.6 => /usr/lib/x86_64-linux-gnu/libX11.so.6 (0x00007f9128654000)
libXss.so.1 => /usr/lib/x86_64-linux-gnu/libXss.so.1 (0x00007f9128450000)
libpython3.6m.so.1.0 => /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0 (0x00007f9127da4000)
/lib64/ld-linux-x86-64.so.2 (0x00007f912c954000)
libGLX.so.0 => /usr/lib/x86_64-linux-gnu/libGLX.so.0 (0x00007f9127b73000)
libGLdispatch.so.0 => /usr/lib/x86_64-linux-gnu/libGLdispatch.so.0 (0x00007f91278bd000)
libfreetype.so.6 => /usr/lib/x86_64-linux-gnu/libfreetype.so.6 (0x00007f9127609000)
libXrender.so.1 => /usr/lib/x86_64-linux-gnu/libXrender.so.1 (0x00007f91273ff000)
libexpat.so.1 => /lib/x86_64-linux-gnu/libexpat.so.1 (0x00007f91271cd000)
libxcb.so.1 => /usr/lib/x86_64-linux-gnu/libxcb.so.1 (0x00007f9126fa5000)
libXext.so.6 => /usr/lib/x86_64-linux-gnu/libXext.so.6 (0x00007f9126d93000)
libutil.so.1 => /lib/x86_64-linux-gnu/libutil.so.1 (0x00007f9126b90000)
libpng16.so.16 => /usr/lib/x86_64-linux-gnu/libpng16.so.16 (0x00007f912695e000)
libXau.so.6 => /usr/lib/x86_64-linux-gnu/libXau.so.6 (0x00007f912675a000)
libXdmcp.so.6 => /usr/lib/x86_64-linux-gnu/libXdmcp.so.6 (0x00007f9126554000)
libbsd.so.0 => /lib/x86_64-linux-gnu/libbsd.so.0 (0x00007f912633f000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f9126137000)
$ cat link.txt
/usr/bin/c++ -fPIC -march=native -O2 -g -DNDEBUG -shared -Wl,-soname,libgui.so -o libgui.so CMakeFiles/gui.dir/gui.cpp.o CMakeFiles/gui.dir/ngpkg.cpp.o CMakeFiles/gui.dir/demoview.cpp.o CMakeFiles/gui.dir/parallelfunc.cpp.o CMakeFiles/gui.dir/__/libsrc/stlgeom/stlpkg.cpp.o CMakeFiles/gui.dir/__/libsrc/visualization/visualpkg.cpp.o CMakeFiles/gui.dir/__/libsrc/csg/csgpkg.cpp.o CMakeFiles/gui.dir/__/libsrc/geom2d/geom2dpkg.cpp.o CMakeFiles/gui.dir/__/libsrc/occ/occpkg.cpp.o CMakeFiles/gui.dir/__/libsrc/occ/vsocc.cpp.o -Wl,-rpath,/home/dow/ngsuite/ngsolve-build/netgen/netgen/nglib:/home/dow/ngsuite/ngsolve-build/netgen/netgen/libsrc/stlgeom:/home/dow/ngsuite/ngsolve-build/netgen/netgen/libsrc/geom2d:/home/dow/ngsuite/ngsolve-build/netgen/netgen/libsrc/interface:/home/dow/ngsuite/ngsolve-build/netgen/netgen/libsrc/csg:/home/dow/ngsuite/ngsolve-build/netgen/netgen/libsrc/meshing:/home/dow/ngsuite/ngsolve-build/netgen/netgen/libsrc/visualization: ../nglib/libnglib.so -lz -lXmu -lX11 Togl2.1/libtogl.a -ltcl -ltk ../libsrc/stlgeom/libstlvis.so ../libsrc/geom2d/libgeom2dvis.so ../libsrc/interface/libinterface.so ../libsrc/geom2d/libgeom2d.so ../libsrc/stlgeom/libstl.so ../libsrc/csg/libcsgvis.so ../libsrc/csg/libcsg.so ../libsrc/meshing/libmesh.so -lz ../libsrc/visualization/libvisual.so -lpython3.6m -ldl -lGL -lGLU
$ python3 -c'import ngsolve; print(ngsolve.__file__)'
/home/dow/ngsuite/ngsolve-install/lib/python3/dist-packages/ngsolve/__init__.py
Dow
6 years 9 months ago - 6 years 9 months ago #1303
by ddrake
Hi Matthias,
It seemed that even though the library was listed in the the linker command, it was not being included in the dynamic library because it was not considered "needed" for some reason.
Just to try something, I inserted
before
in the link.txt file, then did make and make install (see the modified link.txt below). Then
included in its output the line:
That fixed the error with import netgen.gui. Maybe the CMakeLists can be modified with
Dow
modified link.txt
-Wl,--no-as-needed
-lXmu
libXmu.so.6 => /usr/lib/x86_64-linux-gnu/libXmu.so.6 (0x00007f54452c8000)
set (CMAKE_SHARED_LINKER_FLAGS "-Wl,--no-as-needed")
Dow
modified link.txt
/usr/bin/c++ -fPIC -march=native -O2 -g -DNDEBUG -shared -Wl,-soname,libgui.so -o libgui.so CMakeFiles/gui.dir/gui.cpp.o CMakeFiles/gui.dir/ngpkg.cpp.o CMakeFiles/gui.dir/demoview.cpp.o CMakeFiles/gui.dir/parallelfunc.cpp.o CMakeFiles/gui.dir/__/libsrc/stlgeom/stlpkg.cpp.o CMakeFiles/gui.dir/__/libsrc/visualization/visualpkg.cpp.o CMakeFiles/gui.dir/__/libsrc/csg/csgpkg.cpp.o CMakeFiles/gui.dir/__/libsrc/geom2d/geom2dpkg.cpp.o CMakeFiles/gui.dir/__/libsrc/occ/occpkg.cpp.o CMakeFiles/gui.dir/__/libsrc/occ/vsocc.cpp.o -Wl,-rpath,/home/dow/ngsuite/ngsolve-build/netgen/netgen/nglib:/home/dow/ngsuite/ngsolve-build/netgen/netgen/libsrc/stlgeom:/home/dow/ngsuite/ngsolve-build/netgen/netgen/libsrc/geom2d:/home/dow/ngsuite/ngsolve-build/netgen/netgen/libsrc/interface:/home/dow/ngsuite/ngsolve-build/netgen/netgen/libsrc/csg:/home/dow/ngsuite/ngsolve-build/netgen/netgen/libsrc/meshing:/home/dow/ngsuite/ngsolve-build/netgen/netgen/libsrc/visualization: ../nglib/libnglib.so -lz -Wl,--no-as-needed -lXmu -lX11 Togl2.1/libtogl.a -ltcl -ltk ../libsrc/stlgeom/libstlvis.so ../libsrc/geom2d/libgeom2dvis.so ../libsrc/interface/libinterface.so ../libsrc/geom2d/libgeom2d.so ../libsrc/stlgeom/libstl.so ../libsrc/csg/libcsgvis.so ../libsrc/csg/libcsg.so ../libsrc/meshing/libmesh.so -lz ../libsrc/visualization/libvisual.so -lpython3.6m -ldl -lGL -lGLU
