L2-GridFunction .Other()
- alexschlueter
8 years 2 months ago #134
by alexschlueter
L2-GridFunction .Other() was created by alexschlueter
Hi all,
we are trying to solve a problem using a DG method and explicit time stepping. We save the solution of the last time step in a GridFunction u and assemble a BilinearForm with a SymbolicBFI containing u in each time step. u also appears in the DG skeleton integrators. We would like to access the values of u for the degrees of freedom of the neighboring element, just as with ProxyFunction's .Other(), but this method is not implemented for GridFunctions.
Is there another way to get these values?
Thank you for your help
Alex
Alex
8 years 2 months ago #135
by schruste
Replied by schruste on topic L2-GridFunction .Other()
Hi Alex,
As you have seen, Other() is only implemented for ProxyFunctions, as the context in which it is used is restricted to SymbolicBFIs of element_boundary or skeleton-type, i.e. whenever the evaluation at an integration point has to take place the neighbor is (automatically) available. This is more cumbersome for general Coefficient/GridFunction as the Evaluation from one integration point (without further context) would need to check if it is on a facet and then ask the mesh for the neighbor, translate the integration point to the neighbors local coordinates, etc...
If you only want to do operator evaluations only, why can't you formulate the corresponding BilinearForm and use its Apply(·,·) method?
Perhaps you can make an example integral that you want o realize?
The following user(s) said Thank You: alexschlueter
- alexschlueter
8 years 2 months ago #138
by alexschlueter
Replied by alexschlueter on topic L2-GridFunction .Other()
Hi Christoph,
I would like to implement the following Integral
where our flux is f(u)=u*(1-u) (1D for now) and we use for example the Lax-Friedrichs numerical flux
Here, u- and u+ denote the left and right values of u on an interface.
Your are right that we can just use Apply() for a fully explicit time step. But let's say we want to solve semi-implicitly, I would like to do something like
Is there an easier solution for this use case?
v = fes.TrialFunction()
w = fes.TestFunction()
u = GridFunction(fes)
# Lax-Friedrichs, semi-implicit
etaf = abs(n)
phi = 0.5*(v*(1-u) + v.Other(0)*(1-u.Other(0)))*n # error here, u.Other()
phi += 0.5*etaf*(v-v.Other(0))
a += SymbolicBFI(-v*(1-u)*grad(w))
a += SymbolicBFI(phi*(w - w.Other()), skeleton=True)
a += SymbolicBFI(phi*w, BND, skeleton=True)
# .... mass matrix m ...
rhs.data = m.mat * u.vec
invmat = mstar.Inverse(fes.FreeDofs())
u.vec.data = invmat * rhs
8 years 2 months ago #139
by schruste
The obvious (?) solution is to use element_boundary-integrals instead of skeleton-integrals.
Let's consider only the first part of the integral with
In the skeleton-integrator this gets
However, you can also write this term in terms of element_boundary integrals with
In the element_boundary-integrator this gets
so that the neighboring terms add up to your original term:
Does this help?
phi*(w - w.Other())
phi = 0.5*v*(1-u)*n
phi*(w - w.Other())
0.5*v1*(1-u1)*(w1 - w2)*n1 + 0.5*v2*(1-u2)*(w2 - w1)*n2
= 0.5*(v1*(1-u1)+v2*(1-u2))*(w1 - w2)*n1
Does this help?
- alexschlueter
8 years 2 months ago #140
by alexschlueter
Thank you for the idea: element_boundary would indeed work for the example I posted. Unfortunately, I lied about the boundary term (sorry
). We actually need
Am I wrong, or is there no way to restrict element_boundary integrals to inner facets? I guess I could subtract the wrong boundary contribution from element_boundary in a skeleton integrator....
...but that seems very hacky.
phi += 0.5*(v-v.Other(0))
phiR = IfPos(n, n*IfPos(u-0.5, 0.25, u*(1-u)), 0)
a += SymbolicBFI(phiR*w, BND, skeleton=True)
phi = 0.5*(v*(1-u))*n
phi += 0.25*(v-v.Other(0))
a += SymbolicBFI(phi*(w - w.Other()), element_boundary=True)
a += SymbolicBFI(-1*phi*w, BND, skeleton=True)
8 years 2 months ago #141
by schruste
As of now, there is no VOL_or_BND-like term for the element_boundary integrals. Another work around would be to use FacetFESpace-GridFunction (order=0) as an indicator for interior or boundary facet, but that is not much less hacky.
Time to create page: 0.155 seconds
