ngs-special-functions and pip
2 years 5 months ago #4790
by pbmonk
ngs-special-functions and pip was created by pbmonk
I have installed NGSolve on a Mac using pip and all is working well. But I would like to use
I got the code from GitHub but it would not compile (which makes sense since I have no build folders for NGSolve). Is there any way to get access to special functions when NGSolve is installed via pip? I want to use Hankel functions in a scattering code.
Thanks!
Thanks!
2 years 5 months ago #4792
Replied by joachim on topic ngs-special-functions and pip
Hi Peter,
it should work with the pip installer. It installs the ngsolve header files as well.
Make sure to rerun cmake after re-installung ngsolve, or updating the xcode compiler.
What are the errors you get ?
2 years 5 months ago - 2 years 5 months ago #4797
by matthiash
Replied by matthiash on topic ngs-special-functions and pip
Hi Peter,
It's possible to get it running with the pip version, you just need to point CMake to the right directories.
To find out, where netgen/ngsolve is installed, run
In my case, that's
Now take the directory above and add 'cmake', this is where CMake finds the build configuration (same applies for netgen).
The final build call looks like this:
Make sure to run cmake in an empty directory (remove files created by cmake before), otherwise the install dir is not set correctly.
python3 -c "import ngsolve; print(ngsolve.__file__)"
/Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages/ngsolve/__init__.py
git clone https://github.com/ngsolve/ngs-special-functions.git
cd ngs-special-functions
mkdir build
cd build
cmake .. \
-DNGSolve_DIR=/Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages/ngsolve/cmake \
-DNetgen_DIR=/Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages/netgen/cmake
make -j4
Last edit: 2 years 5 months ago by matthiash. Reason: Code formatting
2 years 5 months ago #4798
by pbmonk
Replied by pbmonk on topic ngs-special-functions and pip
Hi Joachim, thanks for looking into this.
I worked on this some more and I see the header files that cmake is looking for in/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/ngsolve/cmake/NGSolveConfig.cmake
/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/netgen/cmake
so I tried
export CMAKE_PREFIX_PATH="/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages:/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/netgen:${CMAKE_PREFIX_PATH}"
cmake ..
make -j4
make ran OK but I got this error message from make
make -j4
[ 4%] Performing update step for 'project_f2c'
[ 8%] No patch step for 'project_f2c'
[ 12%] Performing configure step for 'project_f2c'
<many lines of messages deleted>
Consolidate compiler generated dependencies of target special_functions[100%] Built target special_functions
Install the project...
-- Install configuration: "Release"
CMake Error at cmake_install.cmake:41 (file):
file cannot create directory: /usr/local/ngsolve. Maybe need administrative privileges.
make[3]: *** [install] Error 1
make[2]: *** [project_ngsolve_specialcfs-prefix/src/project_ngsolve_specialcfs-stamp/project_ngsolve_specialcfs-install] Error 2
make[1]: *** [CMakeFiles/project_ngsolve_specialcfs.dir/all] Error 2
make: *** [all] Error 2
so I tried
cmake ..
make -j4
make -j4
2 years 5 months ago #4799
by pbmonk
My post overlapped yours Matthias. I will do as you instruct. Thanks!
2 years 5 months ago #4800
by matthiash
The error you got at the end is what I mentioned with the install directory. Just start in a clean directory and it should work.
