compute L2 error
5 years 1 month ago #3091 by wen jing
compute L2 error was created by wen jing
How to compute the error over a subdomain ?
5 years 1 month ago #3092 by hvwahl
Replied by hvwahl on topic compute L2 error
Hello Wen Jing,
have a Look at the tutorial on subdomains you see that bilinear forms use the `definedon` to determine which domain to act on If you look at the docstring of the Integrate function
help(Integrate)
you will see that is also has an optional Flag 'definedon' which you can use just as as in a BilinearForm to integrate over a subdomain.
Best wishes
Henry
5 years 1 month ago #3093 by wen jing
Replied by wen jing on topic compute L2 error
Thanks for your reply. I tried “ erru3 = sqrt( Integrate(errDD,mesh,order = 2*order, definedon=[2]) )” , but it doesn't seem to be able to use it that way.
TypeError: Integrate(): incompatible function arguments. The following argument types are supported:
5 years 1 month ago #3095 by hvwahl
`definedon` expects a ngsolve.Region object (as stated in the docstring) so you need to give is something like mesh.Materials("region_name")
5 years 1 month ago #3097 by wen jing
Thanks for your help!
Wen jing
5 years 1 month ago #3105 by wen jing
We can compute the error of the subregion, so can we graph the solution on the subregion? If yes, could you give me a general idea? Looking for your reply, thanks!
Wen Jing
Time to create page: 0.179 seconds
