- Thank you received: 6
need help to implement the bound limiter (again...)
- Guosheng Fu
- Elite Member
7 years 1 month ago #761
by Guosheng Fu
need help to implement the bound limiter (again...) was created by Guosheng Fu
Dear all,
I need a bound-preserving limiter to work for scalar DG. (I am posting the same question again....
The problem is that I have a DG-Pk grid function, whose cell averages lie in the bound [r1, r2], but the variations inside each element violate this bound.
So, for each element, I need to access the grid function at certain quad points, and find the min/max values at these quad points. Then, I apply a scaling limiter so that the min/max values at these quad points stay within bound.
This is cheap to perform, if implemented correctly, and is crucial for the robustness of DG compressible flow simulations...
Here I have a plain python implementation of the limiter, but way tooooo slow....
I realized that there is no way for me to put this piece of code to C++ all by myself, so I am turning to the experts for help.... (for sure I will buy you drink if we meet at some imaginary conference later :>)
Guosheng
ir = IntegrationRule(TRIG, 3)
nd = (order+1)*(order+2)/2
DG space: all-dofs-together...
def limit(gfrho):
for i, e in enumerate(fes_rho.Elements()):
trafo = e.GetTrafo()
id0 = int(nd*i)
rho0 = gfrho.vec[id0]
val = []
for p in ir :
val.append(gfrho(trafo(p)))
rhoS = []
rhoSum = 0.
for k in range(3*(order+1)):
tmp = val[k] # density at quad pt
rhoS.append(tmp)
rhoSum += ir.weights[k]*tmp
if order > 1:
rho3 = (rho0-rhoSum)/(1-2*mw)
rhoS.append(rho3)
rhomin = min(rhoS)
rhomax = max(rhoS)
theta = 1
if (rhomin < r1-eps) :
theta = (rho0-r1)/(rho0-rhomin)
if (rhomax > r2+eps):
theta1 = (rho0-r2)/(rho0-rhomax)
theta = min(theta, theta1)
if theta < 1 :
# this is too aggressive, FIXME later
for k in range(nd-1):
gfrho.vec[id0+k+1] = theta*gfrho.vec[id0+k+1] # the update
Guosheng
7 years 1 month ago - 7 years 1 month ago #766
Replied by christopher on topic need help to implement the bound limiter (again...)
Hi Guosheng,
not sure if it helps, but we implemented a new feature last month: You can create numpy arrays of mapped integrationpoints and evaluate a CoefficientFunction/GridFunction in a tight C++ loop on all the points. You could then use numpy functionality to get your desired values efficiently.
I'm thinking of something like this:
Does that help you? This would remove the need for a C++ dependency in your code...
The evaluation of cf/gf makes use of multithreading when inside a TaskManager environment.
# create 3 numpy arrays with x,y and z corrdinates of integration points, i.e. m points per element
xpts, ypts, zpts = np.array(...), np.array(...), np.array(...)
# create ngsolve integration points from them
mips = mesh(xpts, ypts, zpts)
# then in each step:
vals = gf(mips)
# then reshape to mxnelements numpy array and use numpy min/max on the rows
Last edit: 7 years 1 month ago by christopher.
- Guosheng Fu
- Elite Member
7 years 1 month ago #767
by Guosheng Fu
Replied by Guosheng Fu on topic need help to implement the bound limiter (again...)
Hi Christopher,
It works much faster now!
Here is the code, maybe you can help me optimizing it
...... (the for loop over elements makes me nervous)
I am using a rectangular mesh with DG-Q1 finite element.
I need to evaluate the function at four vertices of each square element.
First, I create the integration pionts (inside the reference square, but very close to the four vertices) I used the interior points on the reference square to avoid conflicts for evaluation of L2 functions on the mesh boundaries:
Then, I obtain the mapped ir points of the whole mesh:
Then, I define the following scaling limiter:
Guosheng
eps = 1e-8
ir = IntegrationRule(points=[(0+eps,0+eps),(0+eps,1-eps), (1-eps,0+eps),(1-eps,1-eps)], weights=[1/4,1/4,1/4, 1/4])
xpts = []
ypts = []
zpts = []
for e in fes.Elements():
for p in ir :
xpts.append(trafo(p).point[0])
ypts.append(trafo(p).point[1])
zpts.append(0)
nd = 4 # dofs per element
npts = 4 # number of quad pts
nelems = mesh.ne
def limit(gfrho):
rho0 = gfrho.vec[0:nelems] # cell averages
vals = gfrho(mips).reshape(nelems, npts) # gf at quad points
rhomin = vals.min(axis=1)
rhomax = vals.max(axis=1)
for i in range(nelems):
nn = nelems +(nd-1)*i
theta = 1
if (rhomin[i] < r1-eps) :
theta = (rho0[i]-r1)/(rho0[i]-rhomin[i])
if (rhomax[i] > r2+eps):
theta2 = (rho0[i]-r2)/(rho0[i]-rhomax[i])
theta = min(theta, theta2)
if theta < 1 :
gfrho.vec[nn+k] = theta*gfrho.vec[nn+k]
Guosheng
7 years 1 month ago - 7 years 1 month ago #768
You can use numpy boolean array index assignment for that:
Something like this should work:
The scaling is a bit tricky, but can be done using reshape and np.newaxis (so that you multiply 4 elements of the left hand side with 1 element of the array on the right hand side)
Note that neither .NumPy() nor reshape copy the vector, but only provide views on it, so you manipulate the original GridFunction.
rho0 = gfrho.vec[0:nelems].NumPy()
theta = np.ones(nelems,dtype=float)
mask = rhomin < r1-eps
theta[mask] = (rho[mask]-r2)/(rho0[mask]-rhomin[mask])
mask = rhomax > r2+eps
theta2 = (rho0[mask] - r2)/(rho0[mask]-rhomax[mask])
theta[mask] = np.minimum(theta[mask],theta2)
gfu.vec[nn:].NumPy().reshape(nelems,4) *= theta[:,np.newaxis]
- Guosheng Fu
- Elite Member
7 years 1 month ago #1171
by Guosheng Fu
Dear Christopher,
Thanks for the help.
I have a fast working version now.
I noticed a bug when calling the command
It gives me negative element number, maybe there is something wrong with the mesh...
So, I used the following more direct (and more accurate) one:
(there is one slight issue needs clarification: the forth argument of mip is 'meshptr', whose number is something like 3.38634175e-316, which changes for every run...
what is this number used for? seems to be a pointer...but I am not sure)
For the scaling, the reshape(...) *= do not work, so I just enlarged the theta vector to be the same dimension as the h.o. dofs:
I will buy you a drink, say at the next NGSolve user meeting... (hopefully I can come to join the party this time
Guosheng
mpts = mesh([0],[0],[0])
mpt = mpts[0][3] # this is the number for meshptr
ir = [(0,0),(1,0),(1,1),(0,1)] # reference integration nodes
npts = len(ir)
mips = np.zeros((npts*nelems,), dtype=[('x', '<f8'), ('y', '<f8'), ('z', '<f8'),
('meshptr', '<f8'), ('VorB', '<i4'), ('nr', '<i4')])
for j in range(len(ir)):
mips[4*i+j] = (ir[j][0], ir[j][1], 0, mpt, 0, i)
gfrho.vec.FV().NumPy()[nelems:] *= (theta.reshape(nelems,1)*np.ones(nd-1)).ravel()
Guosheng
7 years 1 month ago #1175
Hm, it returns -1 as element number when the point is not in the mesh (not a well documented "feature" but if you want to evaluate on a grid on a complex geometry its handy - you can just put in the grid and filter out all points which are not in the mesh by removing all with el = -1).
You are right, the 4th entry is a pointer to the mesh encoded as a double. The reason is that to be able to be used in numpy, the underlying c++ class must have a very simple structure. Amongst other things it must fullfil the requirements of StandardLayoutType . That's why we created the MeshPoint class. The BaseMappedIntegrationPoint which is then created and that is taken into the CF evaluation has a too complicated layout (it stores the trafo as a matrix, has virtual functions,...). But using the meshpointer we can construct a BaseMappedIntegrationPoint implicitly on the fly when passing to the CF.
The only pitfall there is, that the MeshPoint doesn't keep the mesh alive, so be aware to keep the Python mesh object alive as long as you use points on them.
Ah in my last line was a mistake, you can't assign to a function call... This should work and should be a little cheaper
See you then in Vienna next year
view = gfu.vec[nn:].NumPy().reshape(nelems,4)
view *= theta[:,np.newaxis]
Time to create page: 0.183 seconds
