Solve STEP Geometry
7 years 2 months ago - 7 years 2 months ago #678
by Username
Solve STEP Geometry was created by Username
When I use 'from netgen.geom2d import unit_square' and set the boundary conditions with the flag 'dirichlet=' left|right'' ( figure 1 ), then the Poisson equation on the unit square with homogeneous Dirichlet boundary conditions is solved ( figure 2 ).
If I import the geometry in the format *.step using 'geo=LoadOCCGeometry ('unit_square.step') ' (the unit-square) and set the boundary conditions with 'dirichlet=' left|right'' flag ( figure 3 ), then the Poisson equation on the unit square with homogeneous Dirichlet boundary conditions is not solved ( figure 4 ).
How to set boundary conditions for files of type *.step? Is it possible to determine several boundary conditions on the walls of a square?
Last edit: 7 years 2 months ago by Username.
7 years 2 months ago #679
by cwinters
Replied by cwinters on topic Solve STEP Geometry
I'm not sure which boundary conditions are loaded from a *.step.
If the boundary conditions are set to strings, you can use the following to print them:
If you have integers as boundary conditon, you can set names using:
Could you please attach your *.step file? Then I can check what is loaded from the *.step file?
ngmesh = unit_square.GenerateMesh()
print(mesh.GetBoundaries())
mesh.ngmesh.SetBCName(0,"somename")
7 years 2 months ago #680
by Username
Replied by Username on topic Solve STEP Geometry
Thanks for your quick response,
STEP file
7 years 2 months ago - 7 years 2 months ago #681
by Username
Using
I determined:
- The number of integers as a boundary condition is equal to the number of planes in the file *.step. There are exactly six of them in 3D for a cube.
- And what about the 2D case where the number of integers is equal to one, since one plane? You can set the name of the boundary conditions at a node?
7 years 2 months ago #682
by cwinters
As it looks like, importing *.step files just makes sense for 3D meshes and 2D surface meshes in 3D.
But for a 2D mesh, some information is not set correctly.
Do you really need to import a 2D *.step file? Generating 2D geometries in Netgen is not very difficult.
7 years 2 months ago #683
by Username
The priority is to import the finished 2D model in the format *.step. In Netgen, when writing a 2D object (line) to a file, the '-bc=' flag is specified with the individual number to be referenced when setting the boundary condition. That is, the boundary condition is set on the line. With the format *.step so can be done? Set a boundary condition on a line, point, node, or finite element rather than a surface?
