Issue with vector-valued FacetSpace
- walker_tr9
- Senior Member
3 years 5 months ago #4274
by walker_tr9
Issue with vector-valued FacetSpace was created by walker_tr9
So I have this space:
Bdy_Space = FacetFESpace(mesh, order=0, dim=2, definedon="", definedonbound="Gamma")
Note: this space has two components, or at least it should.
I then do this:
zero_vec = CoefficientFunction((0.0, 0.0))
And when I try this:
gf = GridFunction(Bdy_Space)
gf.Set(zero_vec, dual=True)
I get this error:
netgen.libngpy._meshing.NgException: Error in SetValues: gridfunction-dim = 1, but coefficient-dim = 2
It seems to think the grid function has only one component. But the Bdy_Space was specified with 2. What is the deal?
I then do this:
I get this error:
- walker_tr9
- Senior Member
3 years 5 months ago #4277
by walker_tr9
Replied by walker_tr9 on topic Issue with vector-valued FacetSpace
Did this get fixed? I noticed Joachim made a commit related to this.
- mneunteufel
- Premium Member
- Thank you received: 59
3 years 5 months ago #4278
by mneunteufel
Replied by mneunteufel on topic Issue with vector-valued FacetSpace
Hey,
yes, it should be fixed now and is available in the latest nightly build.
- walker_tr9
- Senior Member
3 years 5 months ago #4279
by walker_tr9
Ok, so I guess this doesn't update the conda ngsolve package. So I should switch to compiling everything.
- walker_tr9
- Senior Member
3 years 5 months ago #4281
by walker_tr9
So I tried using the PIP installer with the --pre flag, which supposedly gives the latest release. Everything installed properly, but I still get the error noted above about the dimension of the space.
- walker_tr9
- Senior Member
3 years 5 months ago #4282
by walker_tr9
here is a standalone code to reproduce the issue:
#from netgen.geom2d import unit_square
# make the mesh
geo.AddRectangle( (0,0), (1,1), bc = "Gamma")
Om_mesh = Mesh(geo.GenerateMesh(maxh=1.0))
for r in range(3):
Om_mesh.Refine()
Draw(Om_mesh)
print(Om_mesh.GetBoundaries())
# bdy space
Bdy_Space = FacetFESpace(Om_mesh, order=0, dim=2, definedon="", definedonbound="Gamma")
print(" ")
num_Gm_dofs = np.sum(Bdy_Space.FreeDofs())
print("number of FreeDofs for Bdy_Space: ", num_Gm_dofs)
print("Bdy_Space FreeDof mask: ")
print(Bdy_Space.FreeDofs())
# this does not work
#gf.Set((x*y,y), dual=True)
# (this "works", but shouldn't)
gf.Set(x*y, dual=True)
print(gf)
#help(gf)
uu = Bdy_Space.TrialFunction()
IP = InnerProduct(gf,uu)
input("Press Enter to finish...")
the line: gf.Set((x*y,y), dual=True)
is what I need to work, but it doesn't.
# make the mesh
for r in range(3):
Om_mesh.Refine()
Draw(Om_mesh)
# bdy space
print(" ")
print(gf)
#help(gf)
Time to create page: 0.146 seconds
