netgen mesh question, specialcf.mesh_size and specialcf.normal
7 years 5 months ago #488 by Guosheng Fu
I have this question related to the two interesting specialcf for a very long time.... ;)
In particular, I want to check the specific normal direction of an edge in a triangular mesh.
For the mesh size function
h = specialcf.mesh_size,
I can plot it on a triangular mesh as a standard CoefficientFunction, and it looks like (should be) the area.
I guess, when restricting to the edges, it became the edge-length, right? But I can not verify this claim since I don't know now to evaluate a Coefficient Function at an edge manually.... Here is a related question concerning this issue: how to manually evaluate a function that is only defined on the edges? like the stabilization parameter for an HDG method, or its skeleton solution? The approach of MappedIntegrationPoints
mip = mesh(0.2,0.2)
f(mip)
seems not work for edge-wise evaluations...
Then, for the normal direction, the question is similar, I want to know n[0] and n[1], manually, at all the mesh skeleton...
Guosheng
