How can I use Q2-P1dc element pair in a quadrilateral mesh to solve Stokes?
1 month 1 week ago #3651 by Guosheng Fu
Hi Di Yang,
You can hack the Q1 L2 space by removing the bilinear parts. Below is a working example.
Guosheng
Please Log in or Create an account to join the conversation.
1 month 1 week ago - 1 month 1 week ago #3652 by Younghigh
Thank u very much. By the way, does NGSolve provide high order BDFM element directly? If not, how can I design it just in NGSolve instead of using other platforms?
The BDFM element is a reduced element from BDM element. Because I have no idea how BDM is designed in the core of NGSolve developing, how to obtain BDFM elements in quadrilateral meshes is still an open issue for me.
1 month 1 week ago #3653 by Guosheng Fu
I think you can hack a vectorQk+1 space to get a DG version of the BDFMk space on quads (no hdiv-conformity), just removing unwanted high order DOFs.
You can take a look at this thesis for the construction of basis function in ngsolve
www.numa.uni-linz.ac.at/Teaching/PhD/Finished/zaglmayr
All the finite elements are in the source file
github.com/NGSolve/ngsolve/tree/master/fem
1 month 6 days ago #3662 by Younghigh
How is the Qk element L2basis ranked? Is there a law about its ranking?
1 month 4 days ago #3679 by Younghigh
Thank u for my coding. But I am still confused how to hack a vector Q{k+1} space to get a DG version of the BDFMk space on quads. The scalar Qk+1 space is easy to implement but for a vector space, what is the structure of its basis?
(Q1)^2=span{(1,0), (x,0), (y,0), (x*y,0), (0,1), (0,x), (0,y), (0,x*y)},
please tell me how to hack it in the codes to get DG version of BDFM1 space. Note that dim(BDFM1)=4 by the way.
1 month 4 days ago #3680 by Guosheng Fu
First, you shall figure out the basis functions for Qk by yourself. They are classical tensor products of 1D Legendre basis. VectorL2 is simply two copies of Qk on quads.
You can do so by visualize the shape functions of the basis on a unit square without going into details of the c++ code, e.g.,
mesh = MakeStructured2DMesh(nx=1,ny=1)
gfu = GridFunction(VectorL2(mesh, order=2))
Draw(gfu)
for i in range(gfu.vec.size):
    gfu.vec[i] = 1
    if i > 1:
         gfu.vec[i-1] = 0
     input("next?")
© 2019 Netgen/NGSolve
