3D curved mesh questions
7 years 6 months ago #442
by pschroe
3D curved mesh questions was created by pschroe
Dear all,
I want to mesh a unit sphere as you will find in the attached file and have the following two questions:
The parameter N is supposed to control the mesh size.
However, it does only have an effect if N>4.
For N<=4, the mesh is always the same.
How can I obtain a coarser mesh for the sphere?
When curving the mesh as in the script, I can attach a parameter, in this case 3.
Does this simply mean that I'm going to obtain a third-order accurate approximation of the sphere surface?
Thanks, Philipp
Thanks, Philipp
7 years 6 months ago #443
Replied by joachim on topic 3D curved mesh questions
Hi Philip,
you can use the following arguments to obtain a coarser mesh:
geo.GenerateMesh(maxh=1000, curvaturesafety=0.7)
maxh is the global maximal mesh size. Depending on the curvature of the geometry, the mesh-size is locally reduced. curvaturesafetry=x sets a mesh-size to x*curvature-radius.
Not all parameters of the Netgen-gui are ported to python. You can check the available arguments and default values via
>>> from netgen.meshing import MeshingParameters
>>> help (MeshingParameters)
Yes, you are right. mesh.Curve(3) computes a third order geometry approximation. For this we use Demkowizc-style "projection-based interpolation".
