second-order derivatives for vector finite elements
3 months 1 day ago #2423 by christopher
Hi Guosheng,
Do you need it for postprocessing? You could project the function on a VectorH1 of higher order and then take the gradient. If you need it in the form, I think you would need to implement and export it.
The following user(s) said Thank You: tommaso
Please Log in or Create an account to join the conversation.
3 months 1 day ago #2425 by Guosheng Fu
Christopher,
I actually need it for the form. It's a forth-order vector PDE.
I am a bit scared to dig into the c++ code myself. But maybe it worth a try.
As a first step, I just want to work on square/box elements, which might also makes the coding less intensive. Can you suggest where to start with?
Guosheng
2 months 3 weeks ago #2450 by mneunteufel
Hi Guosheng,
have you tried a mixed formulation to reduce the fourth-order problem to two second-order problems like the Hellan-Herrmann-Johnson method in this tutorial ?
Then you maybe could avoid the Hessian operator.
2 months 4 days ago - 2 months 4 days ago #2499 by bl736
Hello Michael,
I am following the demo: The Hellan-Herrmann-Johnson Mixed Method . I would like to know the explicit basis functions for the bending moments, could you point out some accessible references on this for an engineering background user. Many thanks!!
Sincerely,
Bin
2 months 4 days ago #2502 by joachim
Hi Bin,
have a look into the PhD thesis by Astrid Pechstein (aka Astrid Sinwel). Chapter 4.4, in particular page 79.
TDNNS and HHJ use the same finite element spaces for the stress (or moments).
available from here:
www.numa.uni-linz.ac.at/Teaching/PhD/Finished/sinwel-diss.pdf
best, Joachim
2 months 3 days ago #2504 by bl736
May thanks Joachim!!
© 2019 Netgen/NGSolve
